slighty_sykotic wrote:My bluetop head is fine on 14psi.
You should be fine till at least 18-20 i'd say. Probably even higher. I don't think evlgtz was using anything over than std and he was running 18??
--Sykotic
Stealer Of Souls wrote:Maybe you just need new springs?
Springs sag and can wear over time... Sure they didn't mean, "you just need some new springs cause your old ones are sad.".
flygt4 wrote:car was running on the dyno this morning. no issues at 21psi with a silvertop head. thats only on dyno tho , havent got the car back yet and had time to test it out. its still to be tidied up with a road tune.
