Bazda wrote:heat up the area where the gudgen goes through the piston with a gas torch, but dont get it red hot just hot enough until u can push it out with some pliers.
yes, but if you only need 80-100degrees to get enough expansion, why would you waste gas by heating them nearer to 1000degrees?IH8TEC wrote:i've seen the gas torch used on a few motors now. even on mine. seemed to work ok, just make sure you dont get them anywhere near glowing red hot.
fangsport wrote:yes, but if you only need 80-100degrees to get enough expansion, why would you waste gas by heating them nearer to 1000degrees?IH8TEC wrote:i've seen the gas torch used on a few motors now. even on mine. seemed to work ok, just make sure you dont get them anywhere near glowing red hot.
