TRD LSD v's Hilux LSD
Postby beeker » Mon Aug 07, 2006 9:15 am
I'm told that the Hilux LSD's don't have a full lockup feature in them, and with too much throttle they'll spin one side. Apparently there is a 'power lock' or other mods that you can do to fix this.
Anyone know the detail on this, and the options. Just interetsed to understand this more. Any handy links on this topic ?
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby escortman » Mon Aug 07, 2006 5:24 pm
yep my mate just bought a hilux and spins both in a straightline but only 1 goes when doing donuts :lol:
4x4 toyota blizzard offroader
escortman
Postby Rick » Mon Aug 07, 2006 6:23 pm
You can get the Hilux lsd's reshimed to fix the problem.
Postby beeker » Mon Aug 07, 2006 6:44 pm
Rick wrote:You can get the Hilux lsd's reshimed to fix the problem.
I've heard reshimming is a no no for race cars ??
(But personally i dont know what reshimming is)
06 RS4 Avant
beeker
Postby Caveman » Mon Aug 07, 2006 7:08 pm
Nup reshim is kind of like a rebuild, just increases the initial torque so it will lock up sooner and grip harder under load.
We did this to my brothers 4agze which ended up acting like a locker wtf. He had a kaaz unit though, bling bling. I dont know how easy it is to rebuild toyota ones but usually it costs heaps.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby drftnmaz » Tue Aug 08, 2006 1:22 pm
if you look what happens wen you shim them you might as well just lock them because most ppl shim them wayy to much to get the effect they want and there pretty much just always engaged
drftnmaz
Postby beeker » Sat Aug 12, 2006 7:51 pm
Done a bit more research here. Looks like its a "Dana Powr-Lok" which is actually a new LSD unit. Apparently this is much more consistent and has more bite than the std hilux lsd, which is of course very important when racing.
Do TRD make a LSD for this hilux Diff ?
ie better than the std factory lsd item.
06 RS4 Avant
beeker
Postby Mr Revhead » Sat Aug 12, 2006 7:55 pm
used to. but not anymore
Postby NZ_AE86 » Sat Aug 12, 2006 9:11 pm
In my opinion reshimming is a waste of time for a race car. The only way to make them work properly is to have new 'ramps' made.
Are you having trouble with the AE86 Diff? What is the reason for wanting to change it?
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby beeker » Sat Aug 12, 2006 10:11 pm
NZ_AE86 wrote:In my opinion reshimming is a waste of time for a race car. The only way to make them work properly is to have new 'ramps' made.
I'm prepping for 4agte, so need beefed up driveline.
When you say new ramps, I assume this is modification to the LSD and the way it bites ? Who does this type of work ?
06 RS4 Avant
beeker
Postby Drifter4ag » Sun Aug 13, 2006 12:32 pm
steelie gears in auckland will do the shim & rebuild for about $400+ which is pretty good. If you dont want it like a locker just tell them mild shim for circuit or targa car ... drift shim is close to lock but not quite i.e. can get a cert & pass wofs with it
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby beeker » Sun Aug 13, 2006 2:44 pm
Drifter4ag wrote:steelie gears in auckland will do the shim & rebuild for about $400+ which is pretty good. If you dont want it like a locker just tell them mild shim for circuit or targa car ... drift shim is close to lock but not quite i.e. can get a cert & pass wofs with it
Why do so many circuit racers saying shimming is no good ?
06 RS4 Avant
beeker
Postby NZ_AE86 » Sun Aug 13, 2006 3:25 pm
Shimming is just not good enough for real racing.
Current rides;
1986 Levin GT
NZ_AE86
Postby beeker » Sun Aug 13, 2006 6:01 pm
NZ_AE86 wrote:Shimming is just not good enough for real racing.
So it slips ? inconsistent behaviour ? wears out ?
06 RS4 Avant
beeker
Postby NZ_AE86 » Sun Aug 13, 2006 10:27 pm
Well all shimming does is increase your preload it does not have anything to do with the lockup of the Diff, this is controlled by the ramp angles. Many people will tell you they are good enough but they just aren't! If you Shim it too much you end up with a locked diff and any less you end up with a diff that will spin 1 wheel inconsistently so you never know what the car is going to do! The trouble with a locked diff is you loose turn in and require a different car setup and driving style (which if you want to do can work very well but in this case just put a Spool in it). If you are set on a Hilux Diff then get new 'ramps' made and it will work well.
Current rides;
1986 Levin GT
NZ_AE86
hey
Postby ezy10s » Sun Aug 13, 2006 11:13 pm
TRD still do a G series independant for early soarers- Code is RA____ csnt remember the rest but they are still available for them. these will fit into the hilux carrier
Member #244
Gone fishing until further notice
ezy10s
Postby Mr Revhead » Sun Aug 13, 2006 11:15 pm
wil they?
interesting....
41301-ra010
Postby QikStarlie » Sun Aug 13, 2006 11:29 pm
gimme one of them.
mines crap spins up the inside wheel every time, unless you got skinnys on the back
QikStarlie
Postby Jebus » Sun Aug 13, 2006 11:33 pm
Mine skids both wheels every time, as long as you break traction with no turning force (i.e straight line) If you drop the clutch while turning or when the rear axles are travelling at unequal speeds it just single spins.
Jebus
Postby beeker » Mon Aug 14, 2006 7:52 am
NZ_AE86 wrote:Well all shimming does is increase your preload it does not have anything to do with the lockup of the Diff, this is controlled by the ramp angles. Many people will tell you they are good enough but they just aren't! If you Shim it too much you end up with a locked diff and any less you end up with a diff that will spin 1 wheel inconsistently so you never know what the car is going to do! The trouble with a locked diff is you loose turn in and require a different car setup and driving style (which if you want to do can work very well but in this case just put a Spool in it). If you are set on a Hilux Diff then get new 'ramps' made and it will work well.
Thanks, it all makes sense now. Who would be good to make new ramps up in Auckland ? And whats the budget ?
06 RS4 Avant
beeker
