mr pad wrote:Mr Revhead wrote:well same goes for the 800+ RBs. and rotors etc etc.....
and any 3sgte you can get to make 600hp cozmo...
sr's are not over-rated. did one of your mates tell you that? they are wicked tough motors from factory, and are reliable as piss as long as you dont let your oil turn to sludge. So its not a toyota motor... omg. your going to hell etc...
Adydas wrote:A few hundred? man ive been ripped off.
Silvertop wrote:I'm a tad biased mind you
gmacrae wrote:The SR20 is one of the only 4cyl jap engines i'd never want to own, they were built to be cheap - that is all. Every other jap dohc 2l 4cyl on the road is better designed. Yes you can make them go fast, you can make a morris 1800 go fast if you really want to, but its still rubbish.
RS13 wrote:Adydas wrote:A few hundred? man ive been ripped off.
I saw a rwd 1S Corona out at the Waimak a few weeks ago, had been kicked in pretty bad, had a 5spd gearbox though.. isn't that what you want? A W gearbox with an S bellhousing? Take a toolkit out on a Sunday arvo, get a free gearbox, otherwise I've seen a couple at wreckers.Silvertop wrote:I'm a tad biased mind you
Hahah, me too. I don't agree with;gmacrae wrote:The SR20 is one of the only 4cyl jap engines i'd never want to own, they were built to be cheap - that is all. Every other jap dohc 2l 4cyl on the road is better designed. Yes you can make them go fast, you can make a morris 1800 go fast if you really want to, but its still rubbish.
If they're such "rubbish", then why did they start making them in 1986, up until a couple of years ago, without really changing the basic design? They're everywhere! Drifters, track racers, street cars, drag cars.. if they're so cheap and nasty as you say, then why would everybody have them?
JustinSpiderholden wrote:Do you not undertand the term classic, the reasoning for not putting a sr20det into a ta22 is not mainly based on the fact that the sr20det is heavly overrated is more due to the fact that the ta22 is a classic toyota and should not be ruined buy putting a nissan motor between its front struts
its like buying a cosworth 190e and pulling the cosowrth motor to replace it with a 13b
thats my point a classic toyota needs a toyota engine of great heritage
here comes the 3sgte, great rally heritage i belive a few wrc world championships to
the sr20 will never ever be right in a ta22 imo
Mr Revhead, hehe he's lving up in tauranga now and the celica still in nelson i've seen his stock pile of parts so should be all good once he gets it up here and starts work on it again, i give him 15 years
mr pad wrote:JustinSpiderholden wrote:Do you not undertand the term classic, the reasoning for not putting a sr20det into a ta22 is not mainly based on the fact that the sr20det is heavly overrated is more due to the fact that the ta22 is a classic toyota and should not be ruined buy putting a nissan motor between its front struts
its nothing like putting a 13b in a cosworth 190e....
its an old toyota, you are putting a new motor in it. If I shaved off the toyota on the cam covers, and the same with the nissans, would you still care? If so, then congrats. You are smart.
RS13 wrote:If they're such "rubbish", then why did they start making them in 1986, up until a couple of years ago, without really changing the basic design? They're everywhere! Drifters, track racers, street cars, drag cars.. if they're so cheap and nasty as you say, then why would everybody have them?
Ako wrote:Starion 4G63 block + VR4 head + Starion gbox + evo turbo setup = 3s... what?
All for approx $Fckall too.
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 35 guests
