dash warning lights ae92 gtz afm
Postby Fred » Wed Aug 16, 2006 1:57 pm
Sup when i start the car up the Supercharger light, the battery light, and another light which is kind of like a little box with some wavey lines coming out the top, all stay on.
any ideas what it means?
Thanks
White Trueno ae92, 4agte
172kw atw and as bazda put it "lowest reading dyno in auckland"
http://toyspeed.blakjak.net/profiles/profile.php?id=672
http://www.cardomain.com/ride/2124212/1
Black and Gold Trueno ae92, 4agze
14.6@152 (hmmm thats a .69)
http://www.cardomain.com/ride/2160441
Fred
Postby matt dunn » Wed Aug 16, 2006 2:49 pm
that your alternator is stuffed.
Postby Leon » Wed Aug 16, 2006 3:09 pm
Yep, that'd be my verdict too. Your alternator is overcharging to heck.
That's happened to me twice.
Postby Mr Revhead » Wed Aug 16, 2006 3:16 pm
could also be a loose wire.....
i have that issue in my aw11
sometimes it pegs the volt gauge and all warning lights come on
Postby Leon » Wed Aug 16, 2006 3:30 pm
Wouldn't that imply that your alternator could be really savagely spiking from time to time?
Postby Mr Revhead » Wed Aug 16, 2006 3:32 pm
which would imply a rooted regulator
which i changed. does it less now. but still does it.i suspect i know which wire it is. just cbf getting in there again as it requres axle stands, jack, motivation etc
Postby Leon » Wed Aug 16, 2006 3:39 pm
Ah, I see.
Just imagine there is a goat in there, and you'll leap in with great enthusiasm.
If not your pants.
Postby Fred » Wed Aug 16, 2006 4:30 pm
Awesome that is good, well its not but good to know what it is
just had a new alternator put on it, so must be that, if its overcharging it will stuff the battery up hey? and make it go flat? cause thats what happened once had the new alternator.
Fred
Postby Leon » Wed Aug 16, 2006 4:36 pm
Yep. If it did what both of mine did, it overcharged the battery while running, and then quietly drained the battery while parked up for more than about an hour.
I replaced the alternator immediately, so fortunately didn't cook the battery.
