External WG, should it have a perfect seal?
Postby ~SlideWays~ » Fri Aug 18, 2006 3:29 pm
On my external wastegate, there is a tiny tiny gap which is enough to see light through and I guess some exhaust gases to sneak passed. Is this normal or should it be a perfect seal?
~SlideWays~
Postby IH8TEC » Fri Aug 18, 2006 4:03 pm
did you take it apart like i said? and i assume your talking about the diaphram, does it seem worn down so thin it looks see through?
Postby ~SlideWays~ » Fri Aug 18, 2006 4:14 pm
Yep sorted that (was just the nut as you guessed) but I'm talking about the actual gate, not being a perfect seal when it is closed.
~SlideWays~
Postby Bazda » Fri Aug 18, 2006 6:22 pm
There is a retainer ring which creates the seal on the valve, when u bolt it up it presses the ring up making the seal
