How far is normal?
How far is normal?
Postby RS13 » Mon Aug 21, 2006 8:01 pm
Hi
I'm down to 1/4 tank of gas in my AE92, and I've only done 244kms. I notice that when I filled it (yes, filled, I always squirt fuel right up to the nozzel when I fill, and yes, sometimes it does slosh down the side of the car when I drive away!) the gauge only went up to just past 3/4.. hmm.
Its' a bog standard 4AGE AE92, and I occasionally drive it harder than I should, not really "thrashing" it though.. what kind of range should I expect from a full tank? Is it abnormally thirsty, or going by the gauge, would I possibly have a 1/4 tank when indicating empty? Would it be the sender or the gauge?
RS13
Postby flat_0ut » Mon Aug 21, 2006 8:09 pm
let it run to empty and see 8)
flat_0ut
Postby Leon » Mon Aug 21, 2006 8:10 pm
also telling us how many litres went in when it was low would be useful too.
Postby gepsk8 » Mon Aug 21, 2006 8:24 pm
i get low 300's when giving it death. 400+(i would expect) should be for 45 litres,
gepsk8
Postby Dirtbag » Mon Aug 21, 2006 8:45 pm
I get between 8-12kms/l in my ae101 depending on how i drive it.
My mate with an ae92 also has a screwed fuel gauge.... it will not go below half. Mayb a common fault in ae92s?
AE101 GT-APEX Superstrut
My profile!
Dirtbag
Postby RS13 » Mon Aug 21, 2006 9:54 pm
flat_0ut wrote:let it run to empty and see 8)
Yeah, I think thats' probably the best course of action. I'm gonna get a fuel can tomorrow. :)
RS13
Postby deaf_rattle » Mon Aug 21, 2006 9:56 pm
or fill it up, drive for 100kms and then fill up again
that way you know how many litres it takes to do 100kms and you can work it out from there ;)
Postby Dirtbag » Mon Aug 21, 2006 9:56 pm
I once ran the empty light for about 85ks of non granny driving... so that is quite a decent chunk of milage that most people would never try to get.
And yes, i know its not the best for the car to run it that low
My profile!
Dirtbag
Postby RS13 » Mon Aug 21, 2006 10:00 pm
I wish there was another way to check the fuel level other than the unreliable gauge. Oh well. :)
RS13
Postby Loudtoy » Mon Aug 21, 2006 10:03 pm
Dirtbag wrote:I once ran the empty light for about 85ks of non granny driving... so that is quite a decent chunk of milage that most people would never try to get.
Ha 104.3 in my old 101 and rolled into the gas station having just run out of gas, petrol light came on the day before pay day and i still had to get to work and back then to the gas station which was exactly 104.3 k's :)
Don't recomend trying it unless the last .3k is down hill tho
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby Dirtbag » Mon Aug 21, 2006 10:06 pm
My car surged once at about 5.5K, and i thought, shit, f it, ill go do the deed, put 20bucks in and barely got it above empty light again :lol:
My profile!
Dirtbag
Postby NA Drifter » Mon Aug 21, 2006 11:22 pm
1 tank will last me driving my ae86 from Palmy to auckland(500+km)... with the back full of rims and tyres. 1 tank around 40 liters?
Keith
NA Drifter
Postby Adamal » Mon Aug 21, 2006 11:43 pm
I get just under 300kms in my AW with about 33 litres. And it doesn't matter how I drive! :(
Postby Punter » Tue Aug 22, 2006 10:08 am
Could be the float on the end of the arm thing.
I had a car that did that, the float filled with fuel and just sort of flopped around. It would read just above 2/3's when full and anything less than half a tank and it would just show a random amount of fuel.
Punter
Users browsing this forum: Google [Bot] and 1 guest
