WTD: KE30/35 Spring top hats
Postby Bling » Mon Sep 11, 2006 1:43 pm
if thats the right terminology for them.....
I have some non-tapered springs that dont fit my kp struts, so need a pair of KE30/35 spring top hats to use in my kp struts for cheap cheap if anyone has a set lying around and is keen to sell, let me know,
chur chur
Postby fangsport » Mon Sep 11, 2006 5:12 pm
will ke70 fit? have heaps of those.
fangsport
Postby Snoozin » Mon Sep 11, 2006 5:38 pm
KE70's use the tapered springs as well iirc.
Snoozin
Postby Dell'Orto » Mon Sep 11, 2006 5:59 pm
Early ones dont. My sedan has straight and the wagon has tapered. But I think KE70 ones are different to KE30?
Postby Bling » Mon Sep 11, 2006 7:19 pm
Not too sure about the ke70 ones to be honest, i'll pop out and try my springs against one and let ya know.
the catalogue for kings just lists ke30-35 top hats as suitable, but I guess that may not be the limit...
EDIT:
just measured it against a ke70 s/w top hat and it was too small to fit the spring so measured the springs I have
Springs I have:
OD = 140mm
ID = 115mm (ish)
Postby fangsport » Tue Sep 12, 2006 12:59 am
i have 2 top hats, either TE71 or TT132. they will accept up to 150 OD and 115 ID springs.
may be of use.
fangsport
Postby crispy'86 » Thu Sep 14, 2006 1:19 pm
mr crispy could pick up for you if need be :wink:
crispy'86
Postby Bling » Thu Sep 14, 2006 8:49 pm
i've PM'd him crispy, going to try and get ke30 ones first, as they must be best suited going by what i've read. not ruling them out tho
Return to Christchurch / Upper South Island Region
