BTCC were 300ish hp
theres been a TONNE of development done on the cossie over the years
fxgt race wrote:you just need to get everything right before going to a dyno,the power is there.Get a new 2 into 1 front pipe made up if you have a standard one as they are rubbish.check your butterfies are opening fully,check with the engine builders and see what they did with the cam timing.i did my petrol pump to make sure it was good and it wasn't.simple things that i missed before my first dyno run of $550 and changed them for another dyno run to gain another 17 hp at 175 atws.Your engine will come right .
RedMist wrote:NZ_AE86 wrote:What fuel are you using?
Avgas or don't bother!
With that CR, he's more than likely to loose HP with avgas.
AE85coupe wrote:out of interest Mr redmist
why would he lose power using avgas???
BZR4AGE wrote:As for the dyno plot, I wish i have it too, but the guys didn't bother to get a print out because the gain was so little. all I know was before the engine was done it made 87kw atw, now it makes 100kw. Sorry redmist.
