ae85 brakes onto ke70
Postby panda_dan » Tue Sep 12, 2006 9:42 am
Will standard ae85 brakes fit onto a ke70?
I am selling my ae85 brakes - (rotors, callipers, mounting brackets) and the buyer wants to know if they will fit his ke70 before he buys.
Also does anyone know the diameter and thickness of the ae85 rotor? You'll save me getting out the ruler tonight :)
Thanks guys - Danny
panda_dan
Postby Jebus » Tue Sep 12, 2006 9:56 am
Depending on what model brakes he has on the Ke70 ,theyre more than likely to be the same size. Or very close to it.
9" X 10mm
Jebus
brakes
Postby panda_dan » Tue Sep 12, 2006 9:58 am
Thanks ill pass that on.
With the use of the ae85 mounting brackets will the ae85 brakes be a straight bolt up jobbie ?
panda_dan
Postby Jebus » Tue Sep 12, 2006 9:59 am
Hmm... Not sure bro.
Jebus
brakes
Postby panda_dan » Tue Sep 12, 2006 10:01 am
Hmm ok cheers for your help.
Anyo of you other boys and girls done any 85 brake conversions...?
panda_dan
Postby NA Drifter » Tue Sep 12, 2006 3:33 pm
AS far as I know, KE70 and AE85 brakes are the same.. so does TE71. I could be wrong. I found the number on the caliper on TE71 and AE85 are the same anyway... same brake pads etc...
Keith
NA Drifter
Postby AE85coupe » Wed Sep 13, 2006 6:22 pm
ke70 wagon is bigger than ke70 sedan (the wagon brakes are the same size as te71 etc.)
and yes the ae85 brakes will fit on providing everything is there
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby MetalupYoAss » Sat Sep 16, 2006 12:50 pm
yep, ae85 and ke70 wagon front brakes the same, havent seen ke70 sedan ones.. apparently they smaller
MetalupYoAss
Postby Dell'Orto » Sat Sep 16, 2006 1:01 pm
Same thickness, but the sedan ones are approximately 10mm smaller diameter.
