well i discovered id cracked the head on my engine so that has come off and i got a new one which has been acid dipped, its not cracked or warped either but, the valves are sitting there loose, my question is how do i get the valve into those little half round clips, and is there anything i should do to clean up the valves they looks pretty dirty,
With a valve spring compressor As for cleaning them, nah not too much of a biggy. Parts washer might bring them up.
1988 KE70 Wagon - Slowly rusting 1990 NA6 MX-5 - because reasons 2018 Ranger - Because workcar 1997 FD3S RX-7 Type R - all brap, all the time OMG so shiny!
Mike- wrote:ahh k, neway to do it without the right tools?
And you'd be hard pressed to get it all back together without the right tools
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
They're pretty cheap, I think the Powerbuilt one retails at like $35 or so
