AE111 Wiring Fault
AE111 Wiring Fault
Postby gurutasker » Mon Sep 18, 2006 11:17 am
Hey Everyone,
Haven't really had a chance to look at it yet, but I just wanted to know if anyone else with a 1995 BZ-G Levin (Or Trueno) has had this problem.
It's to do with the rear demister switch on the dash. Have replaced it twice now on my gf's car and once on my own, thinking it was the spring release snapping, but on closer inspection this time looking at the connecter at the back it looks like something has shorted and the contacts/unit has melted 8O
Definately a fire hazard, and it was working it's way through the 3rd one when we pulled it out.
If anyone knows anything about these post up, I will put a bit more up once I have pulled one of the rooted ones apart.
:twisted: Wellington's TS Midget :twisted:
gurutasker
Postby AceSniper » Mon Sep 18, 2006 2:41 pm
sounds abit like elc window switches the contacts get buildup from the high current aching clean them an there fine, dono if its the same for you tho
AceSniper
Postby Santa'sBoostinSleigh » Mon Sep 18, 2006 3:01 pm
im smart eh Aaron :)
its inside the switch unit itself somewhere thats getting hot
one of the ones Aaron showed me was cracked and melted quite badly
disect one a take some pics as i suggested :)
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby B1NZ » Mon Sep 18, 2006 6:27 pm
make sure it plugged in propery, maybe its arching?
Your the only person that I've known to have had a problem with this, although the light in my hazard switch is tempremental - oh dear maybe i should check its not frying itself :oops:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby gurutasker » Tue Sep 19, 2006 10:51 am
B1NZ wrote:oh dear maybe i should check its not frying itself :oops:
Definately worth a check mate. From first glance one of the contacts gets quite burnt (To a red like colour)... didn't have a chance to pull it apart last night, got stuck dissecting a DVD drive, proababley wont get a chance tonight either.. but eventually I will :lol:
gurutasker
Postby Alex B » Tue Sep 19, 2006 2:10 pm
Burnt contacts should be black with carbon build up.
Postby NILPSI » Sun Sep 24, 2006 10:48 pm
Mine does exactly the same thing, im on my 3rd one and its dead, the first one lasted a good couple of years, but since i got the first replacement one they have been frying within 3 days of putting it in, thats using it every morning
The switch just stops working (you push it and it doesnt click in and out), but i found that if you hold it down it works, i have been wedging a bit of cardboard in there when i really need it :?
17 Triton - The "free supplied by work" daily
09 Aurion Sportivo - The Daily
97 Trueno BZ-G - The Garage Queen
97 Supra SZ-R - The never ending project... now with added boost!!
NILPSI
Postby Alex B » Sun Sep 24, 2006 10:49 pm
Well if its just due to over current throu the switch. Just use a relay.
Postby gurutasker » Mon Nov 27, 2006 12:31 pm
Update onto this, I checked the Voltage and the current travelling over the circuit, and have also pulled apart a couple of the units.
Travelling between the 2 wires closest to eachother is around 12-15V and up to around 700ma, this doesn't sound like much to me, but it could be possible that it is jumping across the back or internally.
The main issue i found for the button to get stuck is the little wire/plastic combination used to bring the button in and out is getting melted/snapped by whatever is causing the heat inside the unit.
I've heard about this happening to another guy up in Auckland, so it may just be a factory fault?
gurutasker
Users browsing this forum: Bing [Bot] and 12 guests
