any suggestions, got me puzzled
1998 wrote:Are you running the brake booster off the old oil breather pipe? If so not a good idea. The oil breather pipe goes before the throttle body which means off throttle theres no vacum getting to the brakes. Its supposed to run on vacum on throttle off (after the throttle body). If you have modified the old oil breather line to go into the manifold disregaurd what I said![]()
IH8TEC wrote:1998 wrote:Are you running the brake booster off the old oil breather pipe? If so not a good idea. The oil breather pipe goes before the throttle body which means off throttle theres no vacum getting to the brakes. Its supposed to run on vacum on throttle off (after the throttle body). If you have modified the old oil breather line to go into the manifold disregaurd what I said![]()
disregarded![]()
umm, good point abotu the petrol breather one, wasnt' too sure which side it was meant to go on. will try that, thanks.
by the way, new turbo is on
