funny noises movement with steering/axles
Postby bluemaumau » Fri Sep 22, 2006 8:49 pm
4agze with e52 box.
went on a road trip to hamilton last night, i wasnt driving however.
the car was fine
woke up this morning jumped in, drove off, and i noticed some weird noises and movement from the front passenger side.
basically when the car is in gear, with no throttle (decelerating) the car jumps to the left (literally) the steering wheel juddering to that LHS also.
also when right (into intersections etc) whilst declerating loud noises are heard.
really puzzled about this one.
help much appreciated.
i have a few ideas but want to hear others opinions first :? :cry:
thanks
Postby bluemaumau » Fri Sep 22, 2006 10:13 pm
oh i should also mention i took the wheel off, and all hub/steering related items are tight.
Postby sergei » Fri Sep 22, 2006 10:21 pm
Lift up the left front side in the air, put car in neutral, rotate the wheel while looking at the drive shaft, if you hear/feel noise, uneven force + gearbox side of the shaft is moving in not circular manner - congratulations you have destroyed spyder gears inside the diff...
To make sure that you destroyed something inside the g/box - drain little bit of oil. If it is silvery, then, congratulations - gearbox kaput. If not check that CV joints are ok...
Postby bluemaumau » Sat Sep 23, 2006 1:02 am
fuk it was nothing but average driving!
thanks sergei for the help.
could the outer c.v joint being rooted cause those problems tho?
Postby bluemaumau » Sat Sep 23, 2006 5:02 pm
fuk i thinnk ive done the spyder gears, what could have been the cause of this.?
Postby sergei » Sat Sep 23, 2006 5:52 pm
Well, I think it is the hard life it had ;)
When It happened to me, it was just another excuse to get BZ-R box...
Postby bluemaumau » Sat Sep 23, 2006 6:22 pm
gez ive never really done a skid, maybe wheelspun a few times (hey too much torque, what can i say) bu thats it, ohwell, anyone got a e series box?
Postby sergei » Sat Sep 23, 2006 6:23 pm
Have you checked the oil?
Are you sure it is not something else?
Postby bluemaumau » Sat Sep 23, 2006 6:27 pm
yea im goin to talk to toyota mechs on monday see what they think, no havent checked it yet. but its not spinning evenly (passenger side)
Postby Mr Revhead » Sat Sep 23, 2006 11:05 pm
could be a c/v have u jacked it up and looked?
Postby bluemaumau » Sun Sep 24, 2006 12:57 am
yes. how do you tell if a cv is bung tho.?
with out taking it apart?
are these the symptoms of a fuked cv or a cv on its way out? it dosent click
Postby bluemaumau » Sun Sep 24, 2006 12:58 am
maybe its the inner? do these click like outers when there screwed?
Postby bluemaumau » Sun Sep 24, 2006 6:09 pm
bump
Postby sergei » Mon Sep 25, 2006 2:16 am
Inners click randomly (more often on power-on/off)...
The noise could be due to wheel bearning colapsed aswell.
Jack up the car, try moving the shaft and see if it moves and where it moves, if the spyder gear gone the whole inner cv would have huge play in the gearbox. Check the wheel bearing as well, aslo pull other suspension bits aswell just to make sure it is not loose arm or ball joint.
Postby bluemaumau » Mon Sep 25, 2006 10:16 am
thanks sergei, ive done what you said, the result halfshaft rotates really unevenly, and i cant see any looses joints, no play on inner cv
Postby bluemaumau » Thu Sep 28, 2006 6:59 pm
ok i took the car into toyota this avo
hoisted it up.
drooped abit of oil, the dude there reckoned it was too thin "like water"
so we dropped the lot
unfortunately there were some filings in the mixture, which was cloudy.
filled it up with shell 75-90 oil and its been sweet since.!
btw it was running valvoline 75-90,
so dont buy that shit!
hopefully its all good and my diff aint to buggered :(
Postby bluemaumau » Mon Oct 02, 2006 5:34 pm
happened agin today twice.
randomly 20 mins into drive 5th gear 80 kph, low throttle,
shudder shudder whilst in gear and in neutral.
pulled over, drove off 10 mins later again, so i went home and it was sweet.
wtf! what a pain in the ass with exams in 4 weeks!
im thinking something is broken internally and its randomly jamming.
it feels like the wheels gonna fall off!
help :cry:
Postby sergei » Mon Oct 02, 2006 6:58 pm
Check gear oil for metal...
Postby bluemaumau » Mon Oct 02, 2006 7:35 pm
there was some on thursday, but we dropped it and put new oil in.
so i realise the diff wont be as it was when it came out of the factory
but any thoughts on why it was fine for 3 days then shat itself again?
Postby $CENSLS1$ » Mon Oct 02, 2006 8:18 pm
Maybe its got a mind of its own like most things mechnical...
TeamPoon~Building Sex on wheels since '06
$CENSLS1$
Users browsing this forum: Bing [Bot] and 13 guests
