indicator flickering fast means...?
Postby l1ttle_d3vil » Tue Sep 26, 2006 1:49 pm
simple question probably, but i always forget...
is it because the bulb is about to blow, or dodgy wiring?
cheers.
Postby Distrb » Tue Sep 26, 2006 1:55 pm
bulb is gone
Distrb
Regular Poster
Postby Jason T » Tue Sep 26, 2006 1:59 pm
Your blinker fluid has run out you need to buy some more from here
http://kalecoauto.com/index.php?main_pa ... ef5437ce79
Replace the bulb that dont flash :roll:
Fixing Toyota's since '87
Jason T
Postby Silent Knight » Tue Sep 26, 2006 2:02 pm
Silent Knight
Postby Ae92typeX » Tue Sep 26, 2006 5:44 pm
As above, bulb/blinker fluid.
Also can be a wireing fault right up at the indicator stalk very occasionally.
or, the flasher unit itself even less occasionally.
Ae92typeX
Postby edwagon » Tue Sep 26, 2006 10:00 pm
If you don't have a blown bulb, check each bulb in case someone has replaced one of them with a 24v bulb instead of 12v. Easy to do and not immediatly obvious....
edwagon
Postby l1ttle_d3vil » Wed Sep 27, 2006 4:20 pm
ok, its all the left-hand indicators which flash at twice the rate they should do.
* none of them are blown
* they are all 12v bulbs
if it is a dodgy bulb causing the problem, wouldnt it fix itself once that bulb is removed? because ive taken out all the left hand indicator bulbs and on the dash, it is still showing as flashing at twice the normal speed... :roll:
Postby sergei » Wed Sep 27, 2006 4:56 pm
Check the small side bulb on the guard, check if all 3 bulbs (or 4, 5 in some cases) are actually flashing..
Try swapping the flasher unit...
Postby l1ttle_d3vil » Wed Sep 27, 2006 5:51 pm
yep, ive checked the lot of them and they are all flashing. htere is something dodgy with the front one on the bumper though, it stays on all the time i think.
i swapped the flasher unit with one out of a ke70, which strangely enough has ALL of its indicator lights flashing faster, but it was still just the left side when i put it in the starlet so doesnt seem to be the flasher unit...
ill see what else i can suss out about the bumper light... :?
Postby flat_0ut » Wed Sep 27, 2006 6:57 pm
the relay is crapping out? or mabe it wants you to turn quicker :wink:
flat_0ut
Postby big_boy » Wed Sep 27, 2006 10:46 pm
check your bulb wattages ?????
big_boy
Postby Ae92typeX » Thu Sep 28, 2006 8:41 am
check all earthing is good. On the bumper one check that there isnt any crossed (or even melted together) wires.
If all seems ok, I'd tend to have a closer look at the indicator switch to make sure all contacts are clean and good.
Ae92typeX
Postby Alex B » Thu Sep 28, 2006 8:18 pm
Yuh im htinking bad earthage.
