7M had a blown headgasket...
Postby Mr Revhead » Thu Sep 28, 2006 11:28 am
i think that fivebob, like me, has a special place in his heart for internet and common myths and misinformation :wink:
Postby AE85coupe » Thu Sep 28, 2006 7:20 pm
o.k Warrick and Mr King of the condescend (fivebob)
i can't ask him tonight, because it turns out i'm working late
though i would hazard a guess that anti-freeze affects any sealant used when doing a head gasket, so if its done dry, then its probably not a problem
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby UTERUS » Thu Sep 28, 2006 7:36 pm
So....
I fill up the cooling system with anti freeze solution.
I put in the required oil and screw on the filter, run it upto temp then pour in the engine flush and let it idle for the required 10 minute and drain the shitty oil out.
Put new oil in and filter on, do the same as above and see how murky the oil is by this point? If its still poos then i could pour in my other bottle of engine flush and go through the process again.
Once ive got new oil in etc i can now drive it?
UTERUS
Postby Jason T » Thu Sep 28, 2006 11:41 pm
Start with clean oil & filter crank for atleast 30 secounds to get oil presure then start
Once warm any sludge & crud will collect drain & refill
(cut open the oil filter and look at the bits of grit your filter just collected)
Do say 1000kms then flush change oil & filter again
Check your oil cap for signs of sludge/milk shake if you see this dont drive flush again
If in doubt have a read thru here http://www.cygnusx1.net/Supra/Library/T ... fault.aspx
In my opinion no antifreeze on start up is a BS net myth created by keyboard warrior spanner spinners making excuses for bad preparation.
But I also would love to see prof of this please.
Fixing Toyota's since '87
Jason T
Postby AE85coupe » Thu Sep 28, 2006 11:47 pm
jeeze can you not read??? i didn't get that piece of infomation from the net
i got it from an engine rebuilder who also happens to be computer illiterate, so he didn't get it from the net either
and i'd say its to do with the kind of sealant they use
so like i said, if done dry, i'm sure it won't matter
Details of car here
AE85coupe
Postby Dell'Orto » Thu Sep 28, 2006 11:51 pm
Ok, I've also heard this from engine builders - BUT - I also asked Henry from ACL about it, and he said the myth was something to do with antifreeze affecting the surface tension of the water (something along those lines) and not allowing the headgasket to seal...but it is just that, a myth. If anyone should know about gasket failures and what causes them, it'd be that man.
Not taking a dig Richie, just adding my 2c
Postby AE85coupe » Thu Sep 28, 2006 11:54 pm
Mmm, Boost wrote:Ok, I've also heard this from engine builders - BUT - I also asked Henry from ACL about it, and he said the myth was something to do with antifreeze affecting the surface tension of the water (something along those lines) and not allowing the headgasket to seal...but it is just that, a myth. If anyone should know about gasket failures and what causes them, it'd be that man.
thank god an intelligent post
cheers Brad man
thats what we needed to hear
so it is a myth, woohoo end of story
Details of car here
AE85coupe
Postby fuel » Fri Sep 29, 2006 11:16 am
So you finally come to a conclusion that it's a myth when Mmm boost says it but you didn't beleive Mr Revhead and fivebob (who have countless years of experience) who were saying it all along? :roll:
LOUD NOISES!!!
fuel
Postby CaM » Fri Sep 29, 2006 12:52 pm
ryco oil filters FTW
CaM
Postby UTERUS » Fri Sep 29, 2006 2:11 pm
I started it up today, it sounds like a tractor.
Now what :cry:
UTERUS
Postby Mr Revhead » Fri Sep 29, 2006 2:14 pm
tractor as in not running on all cylinders?
or as in little gnome with a hammer?
Postby UTERUS » Fri Sep 29, 2006 2:23 pm
Funnily enough, a bit of both.
Sounds like it is running on 5 cylinders or possibly even a valve not opening?
UTERUS
Postby Mr Revhead » Fri Sep 29, 2006 2:29 pm
run bearing noise maybe?
over the net id just be guessing...
if you suspect a valve issue id pull the cover off and have a look.
maybe you need to get some one to come have a look
Postby UTERUS » Fri Sep 29, 2006 3:50 pm
I now officially hate the 7M.
Is there any way i can check to see if a valve is sticking?
Will a run bearing sound like a hollow knock?
UTERUS
Postby Mr Revhead » Fri Sep 29, 2006 3:56 pm
can do.
to be safe id stop running it and call some one with some experience to come have a look.
Postby Silent Knight » Fri Sep 29, 2006 4:21 pm
Does the knocking etc sound go up and down with the revs?
If it does then I'd probably go as far as saying it *could* potentially be a bent rod...
Otherwise yeh...could be bearings.
Valves easiest way really to tell is to rip the top off and take a look for yourself.
Silent Knight
Postby Jason T » Fri Sep 29, 2006 4:33 pm
Were is this beast ??
I work for beer......... 8)
Ive seen the inside of a few 7M's
Jason T
Postby UTERUS » Fri Sep 29, 2006 4:34 pm
It knocks at idle (700rpm) but when i bring the revs over 1500 the knock goes away but still runs on what seems like 5 cylinders.
Anyone in auckland want to have a look :x
UTERUS
Postby Jebus » Fri Sep 29, 2006 4:36 pm
UTERUS wrote:It knocks at idle (700rpm) but when i bring the revs over 1500 the knock goes away but still runs on what seems like 5 cylinders.
$5 on bearings.
Jebus
Postby Mr Revhead » Fri Sep 29, 2006 4:45 pm
no bet!!
Users browsing this forum: Bing [Bot], Google [Bot] and 19 guests
