HRT wrote:Indeed it is. Have to have metal brackets for extinguishers instead of plastic ones too right?
PopCorn|NZ wrote:
just been through this whole process, taken quite a while as its my first time going through the process.
1.get cage made
2.get cage fitted
3.fill in homologation forms
http://www.motorsport.org.nz/Pdf/T004.pdf
4.fill in log book forms
http://www.motorsport.org.nz/Pdf/T001.pdf
5.send homologation and log book forms away
6.once log book and homologation forms are sent back fill in authority card form and clubsport licence form
http://www.motorsport.org.nz/Pdf/T002.pdf
http://www.motorsport.org.nz/Pdf/A001.pdf
7.wof to get a list of things that failed because they need certifying
8.low volume cert your vehicle
9.wof
this is all assuming you have joined your local car club e.g. Canterbury car club, which you have.
If you haven't here is the link.
http://www.canterburycarclub.co.nz/pdfs ... 20Form.pdf
Hope this helps
Andy a.k.a MadAZN
HRT wrote:Does Matt Black from a spray can in a nice even finish count as finishing paint?
Kender wrote:Check out my new post called in this Chch section titled "your first speed event"
It's quite lengthy, but there's so much stuff a new competitor needs to know that there simply isn't any way to compress any more.
Let me know what you think.
Kender
Return to Christchurch / Upper South Island Region
