The 4age. EFI vs. Carb ??
EFI vs Carb
EFI
34
89%
Carb
4
11%
Total votes : 38
Postby Steelo » Fri Oct 06, 2006 7:06 pm
Hey,
Im in the middle of finding the right engine for my ae85 project.
I am unsure about the pros and cons about going EFI or going with the easier and less pissing around Carbed 4age option.
I want to find out on:
fuel efficiency, reliability etc
So tell me what you think, and any experiences you may have!
2012 Subaru WRX
1985 Toyota Levin
2014 Yamaha MT-07
Steelo
Postby Mr Revhead » Fri Oct 06, 2006 8:29 pm
well what is it for?
carbs can make the same hp as efi.
BUT
efi has better drivability
better consistancy
self adjusting
i would make the decison based on use
Postby Steelo » Fri Oct 06, 2006 9:41 pm
The engine will be going into my ae85 and will be used on the street as a daily driver! So fuel consumption is kinda important. I don't want anything that will be unreliable.
I'm guessing putting in the extra work and going for EFI will be worth it in the long run. A carbed 4age will probable be a cheaper/easy option though (if the engine already has them set up)
2012 Subaru WRX
1985 Toyota Levin
2014 Yamaha MT-07
Steelo
Postby Meadzy » Fri Oct 06, 2006 10:21 pm
efi is cheaper than carbs to set up, always having to tune your carbs would be a bitch aswell for a daily driver
"Keeping it true to the JDM"
J-Spec Group
http://jspecgroup.com/forums/index.php
AE86,200sx,EG6
Meadzy
Postby Mr Revhead » Fri Oct 06, 2006 11:02 pm
yeah if dailey go efi
Postby FXGTV » Sat Oct 07, 2006 2:28 pm
Plus da hoes luv da efi. But seriously, IMO efi is a much better option.
1988 r31 TI Skyline.
1982 ra60 Celica (my Aussie Toyota and axle stand warrior).
ex: 1991 Corolla, 1989 fxgt-v, 1985 aw11. 1992 sw20 gt-s. 2002 glxi Lancer wagon (work hack)
next car - another a-dub please!
FXGTV
Postby matt dunn » Sat Oct 07, 2006 5:26 pm
At Full Throttle, good well set up carbs are as good as EFI.
All other times, EFI makes more power and uses less fuel.
Matt
Postby l1ttle_d3vil » Sat Oct 07, 2006 6:54 pm
ive got an injected 4age in my ke35 which i use as my daily driver.
nothing beats going out to the car on a cold morning, turning the key and it starts first go.
whereas my mate who has a carbied 12a (different engine, but same principals still apply) has to wait about 2 minutes for her car to warm up anytime she wants to go anywhere, and use alot more gas in the process.
if its a daily driver, definitely go EFI.
Postby Lloyd » Sat Oct 07, 2006 6:58 pm
Petrol isn't that expensive.
Go carbs :)
Postby Emperor » Sat Oct 07, 2006 7:00 pm
My RX7's so $&#$% annoying... Took it for a drive one day around Collins Rd, and that area.. Had to do a U, and it just kept stalling no matter how much revs I gave.. and when it finally goes, it stalls at anything under 3,000 rpm
Thank god its not my daily :lol:
12a carb btw
Emperor
Postby AE85coupe » Sat Oct 07, 2006 9:51 pm
fcuk carbs man
i hate carbs
go the efi
and seriously, its just as easy and cheap to set up efi compared to carbs
unless you get crap low quality carbs, which will make it go slower and use more gas
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby strap-on » Sun Oct 08, 2006 10:02 am
haha richie you were waiting for me to read that...
your experience with carbs is a 3a so i dont blame you for hateing em :P
Carbs rock, definatly less fuel efficient, but sound so cool
strap-on
Postby AE85coupe » Sun Oct 08, 2006 11:52 am
strap-on wrote:haha richie you were waiting for me to read that...
yeah carbs are o.k, if its gonna be cheap and easy to do, but in the case of a 4age, its not gonna be cheap or easy
i can forgive carbs on your honda man, infact i like that idea
Details of car here
AE85coupe
Postby strap-on » Sun Oct 08, 2006 12:29 pm
yeah agreed, if the car is efi in the first place tis probably better in the long run to keep it that way, my honda had carbs originally and the IM was easy to source, plus mine are CV carbs which are nearly as good as EFI anyway.
strap-on
Postby Dell'Orto » Sun Oct 08, 2006 2:07 pm
Emperor wrote:My RX7's so $&#$% annoying... Took it for a drive one day around Collins Rd, and that area.. Had to do a U, and it just kept stalling no matter how much revs I gave.. and when it finally goes, it stalls at anything under 3,000 rpm
12a carb btw
Is it a PP or something?
Postby Alex B » Sun Oct 08, 2006 10:18 pm
I think the engine he is looking at already has twin dellorto side drafts on it so set up cost would not be an issue.
Postby Adamal » Sun Oct 08, 2006 10:33 pm
Matt
Using full throttle from idle doesn't give optimal power output throughout the rev range though. Its something I noticed while driving and questioned someone knowledgable about and they confirmed what I believed.
Postby matt dunn » Sun Oct 08, 2006 10:37 pm
Matt
Yes,
but at low speed and not at full throttle,
EFI is better. Which was my point.
Postby Adamal » Sun Oct 08, 2006 10:38 pm
But I digress that I agree.
Postby blackie » Mon Oct 09, 2006 5:44 pm
i dont even know why you would consider carbing a 4age, and how it would be cheaper when they are efi standard.. ........
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1892
When my bros call.. dey get hit wit da chinnggggaayyy
blackie
Return to Polls
