Santa'sBoostinSleigh wrote:with all this 4AGTE talk, we need a FAQ thread for how to build one (reliably) and how much things (generally) cost!
maybe this would stop people dreaming about how easy/cheap it is!
Santa'sBoostinSleigh wrote:no no no, i was meaning in general - i know of so many people (myself included) that wouldnt mind having a 4AGTE, but (some/many) people seem to think its as easy as slapping a turbo on the side
this may be a good idea in Daves case
and im sure he has thought things out in many situations
Karl_Skewes wrote:after being there with the same car and doing a lot of swaps that are similar to what you prepose it comes down to this.
4age na:
never going to have the grunt. you can learn to drive, but thats it.
4agte:
this is one of the best motors you could put in the car.
3sge:
doesn't make the power... even beams.. boring after a while.. just not worth the effort.
ca18det:
it is the year 2006, although i think this motor is cool for it's time, a la fj20... it's past it, people use sr20's now for good reason... maybe you should be peurto rico's next best thing?
1uz/Xjzte:
completely kill the car... too heavy... 3sge is heavy enough.. with turbo, or comparitive motor no good... engine bay can accomodate, but kills fun of car.
something only one suggested above: 13bt:
awesome engine. should sit real well in engine bay, and tunnel should accomodate box no problem... would be up there to decide between this and 4agte.
RomanV wrote:4age na:
Agreed, might be an easy/cheap swap though, till I've got all of the parts necessary to do the other swap? Will make the carina a bit more fun in the meantime.
Seeing as how (from what I can gather) I only need 4AGE extractors, I can cut and shut the intake manifold, use the existing mounts/gearbox/clutch/water lines/etc from the 3AU. correct?
Already got a T series box and hydraulic clutch etc, so no worries there.
RomanV wrote:Hmmm, might see if I can find a cheap old AE82/AE92 or something.
Karl_Skewes wrote:it already has big enough feed, return, and breather lines. Same size as 86.
