And I see that my westy hack still makes more than your westy hack.
Till you get a proper ECU at least
Kevin did run and made 365rwkws best of the day.Silent Knight wrote:Yea it was a good day.
I found out that Kevin brought his MKIV round after I left but I'm not 100% sure whether he had a run with it or not.
I have a few good pictures of the day I'll throw up online later tonight for you all to view.
Kevin got 399.7 last time there is some thing wrong some were, he was not going to put it on the dyno but soon as he now my car was not there he changed his mind lol.Silent Knight wrote:http://mk3supra.co.nz/DynoDay/index.html
Photos for your viewing pleasure.![]()
Matt from what I remember that other MKII scored around 85/87rwkw.
It looked really really bad though.![]()
Can't believe anyone would do that to a Supra although I still don't like the MKII's very much.![]()
John didn't Kevin score allot higher last time?
He got down 398rwkw last time he was on the Dyno did he not?
1998 wrote:Well I made a pretty bad 103kw atw
ezy10s did ~160kw in his 7agte around 1bar.
A few 200kw+ 1jz and 7m motors
quite a few supras turned up
not many nissans, although one which turned up made over 300wkw.
On the torque performance dyno I made 110kw at 90kphr (5500RPM). On the hi velocity dyno at the same wheel speed of 90kphr it was only 65wkw![]()
Suspect a slipping clutch from the trashing I gave it a puke on friday. It was slipping on the track but only after a few laps, I thought it would be fine on the dyno.
Good day overall
method wrote:1998 wrote:Well I made a pretty bad 103kw atw
Good day overall
Cant really compare between different dynos anyway, theres no real standard.
Torque can easily change figures by changing the ramp rate, or the correction factor or even the software version of the dyno.
I have a friend who dynoed his evo and managed 280kw at the wheels when they tuned it at 18 psi, speedfactor retuned it for 24psi and he brought it back to torque, they said it only made 288kw, but he said it felt a shitload quicker than 8 extra kw. Chucked it on another dyno but tuned for 30psi on 98 and hes making well over 360kw at the wheels.
postfach wrote:234kw10.8kw gain since last time, just from installing a front mount
Silent Knight wrote:Nice. I am actually really interested to know what exactly you have done to your 1J?
Also how many K's was on it when you put it in?
Good numbers there for the JZs though.
