bluemaumau wrote:ive always wondered about w2a on mr2s, do you have to run the pre rad all the way to the front? surely not?
1998 wrote:nah dont need gze pistons but we'll see after a few more track days just got new clutch, new race pads, high temp brake fluid and semi slick tyres
They are fine, you may need to just mod the spring to make it a bit more responsive. I had to as I was still getting slight comp surge.slighty_sykotic wrote: 38mm wastegate (probably just a ripoff, i sold my tial )
50mm BOV (modified rip off one)
Why are you buying an LC1 with a g3 for may I ask? Just that Im going to go with the g3 also...slighty_sykotic wrote: New G3 link LEM and LC1 wide band oxygen sensor setup.
yeap that seems to be the benchmark everyone is aiming for, the race for 2 hundy atws, lolslighty_sykotic wrote: Aiming for 200kw at the wheels, at about 20psi.
IH8TEC wrote:1998 wrote:nah dont need gze pistons but we'll see after a few more track days just got new clutch, new race pads, high temp brake fluid and semi slick tyres
get some better suspension man. i sure as hell hope you having been racing it with that suspension you had when i popped around last
l1ttle_d3vil wrote:quick question - i know a higher compression is better for a turboed car; I don't know the technical details of why or anything...so will a turbo run fine on standard compression of an aw11 4agze? (which is 8.0:1)
is this compression going to cause problems, or is it just preference to run turbos on higher compression?
l1ttle_d3vil wrote:hah stupid me, i remember it that way now
how much difference is it? i'm currently running a bluetop engine (9.4:1 IIRC), will there be a really noticable difference if I swap to 8.0:1 compression? the car would probably be used around town quite a bit too, so i won'd be at high revs or on boost all the time.
is it really that noticable, or is it just if you're really picky...
~SlideWays~ wrote:It will have bugger all torque and less fuel economy, not that the bluetop had any torque anyway lol, so go for it.
I assume you are going to run a gze or aftermarket ecu though?
l1ttle_d3vil wrote:~SlideWays~ wrote:It will have bugger all torque and less fuel economy, not that the bluetop had any torque anyway lol, so go for it.
yeah, I will be running a link.
i don't have any sort of set kw in mind. originally it was just a 4age n/a transplant, but the 88kw has got a bit boring now so upgrading...no doubt I will upgrade again after I get bored from this too
ive got a vf10 turbo sitting in the shed at the moment so will probably run with this for now. would 120kw - 140kw out of reach for this sort of turbo? and on the gze injectors? somewhere around there would be the ideal power to start with I think.
basically the reason I was asking is I can get a aw11 4agze for a really good price, but just wondering if the trade-off of lower compression is worth it or if it matters. sounds like it won't matter too much plus I could always raise the compression if I really wanted anyway...
thanks for the advice so far
Users browsing this forum: No registered users and 46 guests
