Replacing factory temp guage with an Aftermarket temp gauge
Postby 2fas4u » Wed Nov 15, 2006 10:25 pm
Toyota MR2 SW2O Turbo Engine Bay.
in ref to the item of interest in the red circle i have found out that this is my temp guage sensor for the factory temp guage. now i want to install an aftermarket water temp guage with Degrees Celcius. now if i unbolted that sensor out, will water start pissing out? if so how can i sztop that from happening so i can install the aftermarket guage. was thinking of electrical than mechanical.
also circled in yellow, is that where the thermostat is positioned.
lastly , wats that circled in blue? cheers. below is a slightly better pic.
2fas4u
Postby Alex B » Wed Nov 15, 2006 10:49 pm
oil pressure sensor circled in blue.
Postby eritate » Thu Nov 16, 2006 12:20 am
THat isnt where the thermostat is... its on the otherside where the cambelt is :)
I am a timewaster. Ignore anything I say
eritate
Postby Adamal » Thu Nov 16, 2006 12:34 am
pyro_sniper2002 wrote:oil pressure sensor circled in blue.
First off, NOTHING carrying oil is that big! Secondly, unless you're running an oil cooler or turbo, there are no oil lines leaving the engine, even then they're not that big, and thirdly, that ain't circled in blue :P
Postby Alex B » Thu Nov 16, 2006 12:48 am
bah i was meaning the purple one. Im not a total n00b. You cant be with 3s's when it comes to oil :lol:
Postby Akane » Thu Nov 16, 2006 4:29 am
The one in blue is just another temp sensor, for the ECU this time (I have no friggin idea why they want 2).
Yes (rusty) water will piss out.
most kits that i've seen comes in a form of a water pipe that you put inbetween the radiator rubber pipes.
GLHF.
