caldina clutch?
Postby strx7 » Thu Nov 23, 2006 7:46 pm
8 hours hmm can we put a stop watch on them??????
Postby gleem » Thu Nov 23, 2006 7:54 pm
yeh im sure they will be slacking off as well,
so i need a new clutch but im thinking i may as well get a heavy duty one if im gunna have to fork out 500 odd to get it installed.. can anyone recommend me a heavy duty clutch kit to get? so far i have been looking at the 'SPEC stage 2/3 clutch kits' on driven performance can anyone tell me anything about these?
gleem
Postby strx7 » Thu Nov 23, 2006 10:45 pm
I'd honestly like to see 1 guy do a Caldina/GT4/4wd corolla clutch with only 8 hours of labour. If the guys knows them inside out then it'd POSSIBLY be do-able, otherwise dreaming.
You do realise you have to drop the entire engine and gearbox out the bottom, which means removing both engine mounting beams, splitting them apart then putting it all back together? If your car hasn't had a cambelt & water pump done, i'd reccomend doing them while the engine is out.
Postby gleem » Fri Nov 24, 2006 9:17 am
They might have a few people on the job im not sure but they said they have done some before, cambelts been done so you would expect the waterpump to have been done
gleem
Postby Santa'sBoostinSleigh » Mon Nov 27, 2006 6:14 pm
gleem wrote:They might have a few people on the job im not sure but they said they have done some before, cambelts been done so you would expect the waterpump to have been done
assumption is the mother of all fcukups
do it at the same time if its anywhere near doing again
a cambelt+tensioners+water pump etc is cheap in comparison to labour of pulling the motor out!
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Mr Revhead » Mon Nov 27, 2006 8:39 pm
if you dont ask for.... dont expect it to be done
Postby gleem » Mon Nov 27, 2006 10:12 pm
i will ask them to check they waterpump as well, dont you have to take the belt of anyway too check / replace this?
gleem
