VVT Trouble
VVT Trouble
Postby RevolutionStarlet89 » Mon Oct 16, 2006 3:28 pm
OK so i got my vvt light and switch in to turn it on-off-auto.....BUT, when the switch is on auto (like normal vvt) the light will come on if i lightly press the accelerator.. My car has been converted from auto to manual before i brought her and the comp has been changed to a beltronics 1 i think, not sure thou. From what ive herd when vvt is on when the car is idling it makes it idle really rough but mine dosn't do anything.... Any1 got any ideas??????
SKoty
Current Current Ride: 1992 Toyota Trueno Gt Apex
Ex-Current Ride: 1991 Toyota Levin Gt Apex(Written Off)
Previous Ride: 1989 Toyota Starlet XL
RevolutionStarlet89
Postby Silent Knight » Mon Oct 16, 2006 3:33 pm
I didn't know Beltronics made ECUs... :lol:
Silent Knight
Postby RevolutionStarlet89 » Mon Oct 16, 2006 3:36 pm
as i sed, not sure..... just a name that came into my head lol :D
SKoty
RevolutionStarlet89
Postby strap-on » Mon Oct 16, 2006 6:49 pm
maybe you got the wrong line on the computer? like you got the tps or something
strap-on
Postby Mr Revhead » Mon Oct 16, 2006 7:15 pm
VVT coming on on light throttle is normal
Postby RevolutionStarlet89 » Mon Oct 16, 2006 9:23 pm
Mr Revhead wrote:VVT coming on on light throttle is normal
reason for it not idling rough??????? when my foot is flat on the throtle the light dosent come on either........... wots tps??
SKoty
RevolutionStarlet89
Postby slighty_sykotic » Mon Oct 16, 2006 9:56 pm
You got wrong wire...
Wat wire is it hooked 2?
--Sykotic
slighty_sykotic
Postby Sideros » Mon Oct 16, 2006 10:44 pm
TPS - Throttle Position Sensor.
Sideros
Signwriter
Postby phat_levin » Mon Oct 16, 2006 11:07 pm
i helped him do it and its hooked to the 7th wire from the left on the 26 pin plug, exactly the same as mine, except his wire isnt the same colour as mine, neither are some of the others in that vicinity...
and na tps is on another plug to the ecu....
phat_levin
Postby Alex B » Mon Oct 16, 2006 11:09 pm
Does it not say what the pins are if you take the cover off?
Postby phat_levin » Mon Oct 16, 2006 11:18 pm
u mean the cover off the ecu? we went off the toyota manual which was the same as what they had on club4ag
phat_levin
Postby slighty_sykotic » Tue Oct 17, 2006 11:15 am
Then if its the correct wire (which I still don't believe), what have you got connected to it?
A led with a resister to a 12v+ supply? Nothing else?
--Sykotic
slighty_sykotic
Postby phat_levin » Tue Oct 17, 2006 11:21 am
well if its the wrong wire then its different to every ecu pin diagram i have ever seen, and different to my car which is the same as his.
its connected to a switch, vvt solenoid on centre pole, ecu on the other pole and ground on the other pole with an led running off the vvt solenoid wire to 12v supply with resistor etc.
im convinced his vvt does not work at all because with the engine off and the key on u can hear my solenoid activating wen u flick the switch but with his it does nothing.
also, wen driving, his vvt light comes on with even a slight press of the accelerator, so doing 80-90km/hr in 4th gear the light is constantly on. and with WOT the light goes off, even wen ur doing low revs.....
phat_levin
Postby RevolutionStarlet89 » Sun Nov 26, 2006 3:31 pm
Bump
SKoty
RevolutionStarlet89
Postby Dell'Orto » Sun Nov 26, 2006 8:43 pm
More suited to here ;)
Postby matt dunn » Sun Nov 26, 2006 8:50 pm
phat_levin wrote:well if its the wrong wire then its different to every ecu pin diagram i have ever seen, and different to my car which is the same as his.
You do realise that auto and manual ECU's have completely different pinout's ?
Wasn't his converted from auto to manual, probably still has the Auto ECU as I doubt anyone would bother changing the whole loom to convert to manual.
Postby phat_levin » Sun Nov 26, 2006 9:24 pm
well how do we find the right wire then? im sure we got the right one coz we went off the diagram?
phat_levin
Postby RevolutionStarlet89 » Mon Nov 27, 2006 10:48 am
ok we never thought that it would still have an auto ECU!!! have found the right wire now, but im sure that VVT is not currently working as a factory car would (ie it does not go at all). once we wire up the switch to the right wire we will of course be able to confirm this. but in light of the fact that this car is a manual with an auto ecu, should something have been done during the conversion to enable VVT to function?????
SKoty
RevolutionStarlet89
Postby Mr Revhead » Mon Nov 27, 2006 11:00 am
nope. will work as normal.
what makes you think its not working?
Postby RevolutionStarlet89 » Mon Nov 27, 2006 11:21 am
Because its f***** slow lol.
SKoty
RevolutionStarlet89
Users browsing this forum: Google [Bot] and 2 guests
