Caldina 1997 Headunit too wide for standard gap??
Postby Tegteg » Mon Nov 27, 2006 6:01 pm
Hi all,
Just bought a 1997 Caldina (I think it's a ST19 something), and went to transfer all my sounds over. Finally got the dashboard trim off, but the gap in the dashboard where the standard headunit went seems to be too small for my headunit. Went to Repco and measured up some others as well and they all seem to be too big as well.
The hole is a double DIN size, and the headunit is a normal single DIN, but is about 3mm too wide either side and 3mm too tall if I use the stock brackets already in the car. I have already played around with changing the depth and angles and stuff but the gap really is is too small. Am I missing something or do I have to adjust the hole size with a hacksaw?
Thanks guys for any help.
Tegteg
Postby Santa'sBoostinSleigh » Wed Nov 29, 2006 2:23 pm
my gear went in my caldina fine and its just normal panasonic
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Mr.Phreak » Wed Nov 29, 2006 2:44 pm
I've put a couple of units into 'dinas and they were fine.
You're not trying to use a mounting cage are you??
Mr.Phreak
Postby Punter » Thu Nov 30, 2006 4:24 pm
Yea my mates GTT is the same HU sticks out from the dash about 25mm, looks real shite. And he had a shop install it.
My car was a bit narrow so I just shaved the plastic back a bit, looks mint now.
Punter
Postby Mr.Phreak » Thu Nov 30, 2006 4:37 pm
Most detachable face units are designed that way so it appears that nothing is there when the face is removed.
Mr.Phreak
Postby snwtoy » Thu Nov 30, 2006 5:54 pm
Punter wrote:Yea my mates GTT is the same HU sticks out from the dash about 25mm, looks real shite. And he had a shop install it.
Not mine. There's room to mount the head unit further back so the face sits flush. Lazy shop installer.
In answer to the original question - they are standard din width. You have faulty measuring equipment? :lol:
snwtoy
Postby XERO » Fri Dec 01, 2006 8:49 am
Same here as SNWTOY I have replaced my head unit too...
You are not trying to install it with the removable suround are you?
If so this will not work... Its will then be to wide...
You can however use a spacer and a single din head unit, and fit it into the space fine. Using the original brackets... 8)
Altezza RS200 Z Edition
For performance parts :: www.drivenperformance.co.nz
XERO
Postby Santa'sBoostinSleigh » Fri Dec 01, 2006 8:53 am
25mm is a pretty big stickout
i'd be complaining to the shop
mine mounts nice and flush, and its detachable face
as said above, when the face is off, it should be flush with the dash
Santa's Mega Sale
Postby Punter » Fri Dec 01, 2006 3:19 pm
Santa'sBoostinSleigh wrote:25mm is a pretty big stickout
Yea I told him it was a shit house job and he should have let me do it.
But hey, I can only offer.
Punter
Postby snwtoy » Fri Dec 01, 2006 9:57 pm
Mine's flush with the face ON. Recessed with the face off :D
snwtoy
Postby Tegteg » Wed Dec 06, 2006 8:16 am
Thanks eveyone. I'll try and recess it a bit, otherwise I'm going shopping for a hacksaw this weekend.
Tegteg
Postby JT » Fri Dec 08, 2006 9:35 am
What sort of headunit is it? Pioneers, and maybe others, come with a plastic surround that clips onto the front. Take it off the headunit and see if it fits in the gap. Can you post of picture of the headunit sitting in the car and where it is not fitting?
JT
