price for replacing headgasket
Postby 2fas4u » Mon Nov 27, 2006 12:30 am
it was running sweet in the first few weeks then bamn, the temp guage went hay wire. havent done any mods or hard driving yet as it's my daily driver till i get skyline sorted so cant really afford to thrash it around.
2fas4u
Postby 2fas4u » Mon Nov 27, 2006 12:31 am
now, the radiator overflow bottle boils and rad cap screams.
2fas4u
Postby Akane » Mon Nov 27, 2006 8:43 am
lolol, get it fixed then.
Postby Mr Revhead » Mon Nov 27, 2006 8:44 am
right. stop driving it or you will need a new engine.
my advice is to book it in for repair. at the same time ask about a loan car.
Postby 2fas4u » Mon Nov 27, 2006 4:44 pm
if only money grows on trees.
2fas4u
Postby Mr Revhead » Mon Nov 27, 2006 4:47 pm
well your other option is to keep driving it.
which is likely to result in it dying, possibly making you late to work.
and costing you a lot more for a new engine.....
Postby RED TOP MR 2 » Mon Nov 27, 2006 5:31 pm
book it in get it sorted youll probably get a month to pay it anyway.your car is going to be nailed at the rate your going.
RED TOP MR 2
Postby 2fas4u » Mon Nov 27, 2006 6:06 pm
RED TOP MR 2 wrote:book it in get it sorted youll probably get a month to pay it anyway.your car is going to be nailed at the rate your going.
oh so i can take the invoice and pay at a slightly later date with toyota dealer service centers?
2fas4u
Postby flygt4 » Mon Nov 27, 2006 6:10 pm
just keep driving it , itl be fine , i promise :wink:
flygt4
Postby 2fas4u » Mon Nov 27, 2006 6:19 pm
flygt4 wrote:just keep driving it , itl be fine , i promise :wink:
if it blows, can i borrow your trueno or caldina then. :lol:
2fas4u
Postby flygt4 » Mon Nov 27, 2006 6:26 pm
in your dreams.
flygt4
Postby 2fas4u » Mon Nov 27, 2006 11:14 pm
Mr Revhead wrote:right. stop driving it or you will need a new engine.
do just headgasket or thermostat? how much you guys charge all up for headgasket job including and excluding thermostat? do i have to pay all at once or is there provision to spread out payment say over 1-2months. cheers in advance.
2fas4u
Postby Al » Mon Nov 27, 2006 11:20 pm
Maybe you should ring the service dept or do the work yourself and save 80% of the cost.
Al
Postby 2fas4u » Mon Nov 27, 2006 11:38 pm
dont have the equipment and knowledge or space or time. if i had all that, sure. i can change filters and that sorta stuff but when it comes to headgaskets, it's bit over complicated. working in retail and coming close to christmas, i am rostered for crazy hrs. dont have another car to use either.
2fas4u
Postby Alex B » Mon Nov 27, 2006 11:41 pm
As warwick has already said. Enquire about a loan car when you ring up.
Postby Bling » Tue Nov 28, 2006 12:03 pm
ride a bike if you dont have money to get it fixed.
ride your bike to a garage or anywhere, and ask for a price to check and fix it. some will offer hire purchase etc
Postby Mr Revhead » Tue Nov 28, 2006 12:08 pm
:lol: bike from karori to the hutt?
bugger that
Postby Akane » Tue Nov 28, 2006 4:57 pm
lolol, I don't think you're desperate enough to get your car fixed.
Just let the man do his thing, he'll soon learn it the Akane (hard) way.
Postby big_boy » Tue Nov 28, 2006 10:40 pm
Akane wrote:
HRT wrote:Thats not a leakdown test at all. Leakdown test is where you get the cylinder you are checking to exactly TDC and use a leakdown tester to put compressed air into the cylinder and measure the amount of leakage of the air. Typically about 10% past the rings. If it is higher then there is a likely leak.
Can use the test for burnt valve, damaged pistons/rings, blow head gasket etc. If you hear air escaping from the exhaust pipe then its an exhaust valve issue, something in the inlet then its inlet valve, excessive air out the filler cap then something with pistons/rings and if you have bubbles coming through the radiator then its likely a blow head gasket.
I always thought that was the "compressed air / compressed cylinder test", I stand corrected, thanks for the updated info.
no you were right leakdown test is with oil & for rings cylinder leakage test is what HRT is talking about with the compresser ect..
big_boy
Postby Lloyd » Tue Nov 28, 2006 11:19 pm
Cylinder leakage and leakdown are the same test...
Users browsing this forum: Bing [Bot] and 20 guests
