Water to air Intake.
Postby Stealer Of Souls » Tue Nov 28, 2006 1:27 pm
I think most of these "don't get it too cold" theories are based upon tuning systems to suit the new conditions.
Like have sub zero intake charges. Most people say that you just can't cool down the intake charge too much. But there are dyno plots showing the results after tuning everything to match the very cold intake. And it's always good.
If fuel becomes harder to atomise when very cold then there is probably some trick to compensate and optimise everything. Increase rail pressure, different nozzle design. I don't really know.
'86 AE85.5 Levin
Stealer Of Souls
Postby SUBARUCONVERT » Tue Nov 28, 2006 5:15 pm
Stealer Of Souls wrote:Dual IC systems has always interested me... Always wondered if it would be a good drag car idea...
Dry ice intake cooler might be worth it. But if you got the intake too cold you'd need to retune everything to suit. And you'd need to keep topping up the dry ice...
If u have a decent first intercooler then u dont need a seceond one, in my legacy with FMIC, at WOT 12-13psi i usually have about 7-13 deg hotter than ambient temp at the throttle body.
3ST150
SUBARUCONVERT
Postby Stealer Of Souls » Wed Nov 29, 2006 8:26 am
That's true. But if you had a iced W2A IC after your FMIC you could almost guarantee a colder than ambient intake. And by using two they could probably be marginally undersized to reel the weight back in to something not too heinous...
Just a thought. Would be a pretty limited use idea I suppose.
'86 AE85.5 Levin
Stealer Of Souls
