Hi all,
Just bought a 1997 Caldina (I think it's a ST19 something), and went to transfer all my sounds over. Finally got the dashboard trim off, but the gap in the dashboard where the standard headunit went seems to be too small for my headunit. Went to Repco and measured up some others as well and they all seem to be too big as well.
The hole is a double DIN size, and the headunit is a normal single DIN, but is about 3mm too wide either side and 3mm too tall if I use the stock brackets already in the car. I have already played around with changing the depth and angles and stuff but the gap really is is too small. Am I missing something or do I have to adjust the hole size with a hacksaw?
Thanks guys for any help.
