FWD Gearstick "Floppy"
Postby KE25-KP30 » Sat Dec 02, 2006 4:49 pm
I'm new to the FWD thing, and wondered if a "Loose" or "Floppy" gearstick can be fixed. I.E Is it a bush like the W5*'s that can be replaced, or is it the sign of a well worn gearbox?
The car's an EP71 Starlet Turbo, no ideas what the gearbox is tho sorry.
Much Appreciated :D
KE25-KP30
Postby DexGT » Sat Dec 02, 2006 5:52 pm
your car has cables operating the box , if the gear stick is "floppy " the spring on the gear change may have come lose or broken . The other common thing is the gearbox end of the cables has a rubber bush and these can crap out over time , I have heard you can replace these with a bearing to remove the slop .
Hope this helps 8)
DexGT
Postby KE25-KP30 » Sat Dec 02, 2006 11:59 pm
Ah huh, cheers for that. I'l have to chuck it up on the hoist some time and see if I can sort something out!
Ta
KE25-KP30
Postby Zak » Sun Dec 03, 2006 8:27 am
No need to put it on the hoist the cables are on the top of the gear box. Just pop the bonnet and have a look.
Zak
Postby thaphatty » Sun Dec 03, 2006 5:33 pm
also people who drive with their hand on the gear stick for great periods of time can wear out the selector shafts, which would be alot more difficult to replace than just the bushings
thaphatty
Postby loose_unit » Sun Dec 03, 2006 9:46 pm
Broken selector cables are common in starlets, id put my money on that.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby KE25-KP30 » Mon Dec 04, 2006 10:30 am
Cheers, a few things to check out!!
Broken selector cables?? Excuse my silly question, but wouldn't that make it not be able to change gears? It still changes smoothly but it's just loose (Compared to K50's and W55's).
Sorry, also wondering... What gearbox will this have, and is there an OE LSD that will fit the car?
KE25-KP30
