gmacrae wrote:bah! thats not a manifold This is a manifold!
Bazda wrote:for a 6 cylinder they should have made that split pulse, would of worked much better, also should of used slip joints to avoid cracking at high temps + didnt even make use of a megaphone setup with reverse cone. Not much maths involved in that.
sergei wrote:Has anyone noticed the hole in the block on the pics above?
gmacrae wrote:haha you reckon? Split pulse is a myth.
Bazda wrote: also should of used slip joints to avoid cracking at high temps + didnt even make use of a megaphone setup with reverse cone. Not much maths involved in that.
strx7 wrote:gmacrae wrote:haha you reckon? Split pulse is a myth.
You've never seen/felt the difference between a divided and non divided manifold on a 12A or 13B have you?
split pulse is a myth? (tui ad) YEAH RIGHT
gmacrae wrote:Bazda wrote:for a 6 cylinder they should have made that split pulse, would of worked much better, also should of used slip joints to avoid cracking at high temps + didnt even make use of a megaphone setup with reverse cone. Not much maths involved in that.
haha you reckon? Split pulse is a myth. That manifold was designed by the smartest people/computers in the business, swapping from an hks/style single manifold to the one above has gained many people over 100rwhp increase in power at the same boost level.![]()
Still, it costs $2.5k US so you'd expect it to be pretty good
sergei wrote:I think it is opposite => higher revs shorter runners (reasoning is due to wave length being shorter at higher frequency)...
Users browsing this forum: Majestic-12 [Bot] and 7 guests
