confuziling missing + more probs now HELPPPPPPPppppppp......
Postby 79rolla » Sun Dec 10, 2006 3:51 pm
HELP my 4k is skiping
its not the dizzy or the leads
im pritty sure its not the plug eather
its numder 3 to if that helps
i cant figure it out
im going to go out and dubble cheack its not the plug soon
any ideas?
thnx
past: AE82 FXGT
79rolla
Postby 79rolla » Sun Dec 10, 2006 4:03 pm
oh and if it helps i just put my extracters on like 2 days ago
not sure how long its been skiping for
past: AE82 FXGT
79rolla
Postby 79rolla » Sun Dec 10, 2006 4:45 pm
ok im pritty sure its not the plug
plese anyone HELP!!
past: AE82 FXGT
79rolla
Postby Dell'Orto » Sun Dec 10, 2006 5:07 pm
Spray a bit of carb clean over the manifolds where they bolt to the head. If it goes normal theres a leak there.
Postby 79rolla » Sun Dec 10, 2006 5:10 pm
carb clean??
whats that?
i dont think i have any
past: AE82 FXGT
79rolla
Postby Dell'Orto » Sun Dec 10, 2006 5:15 pm
Carb clean is carb clean, its available from any car parts place. Basically you need to check if there is an intake leak, maybe listen for any hissing noises around that area.
Postby 79rolla » Sun Dec 10, 2006 5:18 pm
there is kind of hissing noise i asumed it was the ramflo dfilter but obliously not
ill go cheak it out
if thats the problem how do i fix it?
tighten the bolts up?
or will i need a new seail?
past: AE82 FXGT
79rolla
Postby 79rolla » Sun Dec 10, 2006 7:16 pm
ok now i relly dont like this
one of the bolts at the bottem on themanifolds wont go in proply i think the thred is $&#$%
but iv put it back the way i was and now it will only idle if i give it gass or choke
when its revs get low it just stalls(at revs higher then it normy stalls at)
its almost like its running on 2 syilenders except its not(i cheaked)
and when i get it to idil it backfiers a bit
past: AE82 FXGT
79rolla
Postby 79rolla » Sun Dec 10, 2006 8:36 pm
anyone????
past: AE82 FXGT
79rolla
Postby Dell'Orto » Sun Dec 10, 2006 8:43 pm
Did you use a new gasket? sounds like its got a pretty meaty air leak. Check the points too, they can sometimes slip and go miles off where they're meant to be.
Postby 79rolla » Sun Dec 10, 2006 8:47 pm
umm no i probly shoulda used a new gaskit
everything els is lined up fine
anything i could to seal it temireily? till i can get it proply sorted out?
would sum sealint handil the heait of the exaust?
past: AE82 FXGT
79rolla
Postby Dell'Orto » Sun Dec 10, 2006 8:58 pm
Yup, its called Maniseal. Take off your manifolds, put a bit of that on the gasket faces and torque them back up. Ought to seal it up good
Postby 79rolla » Sun Dec 10, 2006 9:22 pm
even with the thred inside the engin wreacked?
not sure if this is normail but it runs fine whe driving it only have big problems when idoling
past: AE82 FXGT
79rolla
Postby fj40cruzapete » Sun Dec 10, 2006 10:04 pm
79rolla wrote:problems when idoling
who is it idoling?
fj40cruzapete
Postby 79rolla » Sun Dec 10, 2006 10:07 pm
will only idle with choke on and when does idles fast and backfiers
wont idle without choke
past: AE82 FXGT
79rolla
Postby repowered » Sun Dec 10, 2006 11:17 pm
79rolla wrote:ok now i relly dont like this
oh that sucks when the thread is pooed, my 5k had a dodgy one, just got tight enough.
could get someone in the know to retap itand use a bigger bolt
Rollin!
repowered
Postby solitaire » Mon Dec 11, 2006 8:47 am
who is it idoling?
Bahahaha :lol:
AE92, KZJ120, KDJ120
solitaire
Postby Dell'Orto » Mon Dec 11, 2006 11:12 am
79rolla wrote:even with the thred inside the engin wreacked?
Just wedge a bolt in there, one of my one stripped and I just jammed the bastard in place til I could get a helicoil done.
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
