My Dyno Sheets - give me some comments
TRDmod
Post by TRDmod »
This is my Dyno sheets, this one is standard only with a hks cat back 3inch and cold air intake.
Have you got the hots? for what's in the box with the dots? ..... 0800 30 40 50
Domino's Pizza.....
TRDmod
This one is a lil mod
Post by TRDmod »
This one is with a turbo netics 450 rated turbo. two settings here, high boost is 15.8 and the low boost is 12 psi. custom manifolds, cold air intake, 3inch.
Domino's Pizza.....
Post by Dell'Orto »
Your boost curve sucks, any form of boost controller in there? KiwiMR2's old car held boost beautifully with fairly similar mods.
TRDmod
yes
Post by TRDmod »
the first dynograph has no boost controller its standard
the second one looks a lil better, it has profec type s , the one with three dials
which on ar eyou refering to? the second ones boost curve doesnt look too bad
but the first one sucks i must agree, jsut standard..
Domino's Pizza.....
Post by Dell'Orto »
The first one. The 2nd one is much improved, good top end there too
dougsop
Post by dougsop »
not bad for a GT4 with out touching the internal :D
keep it going 8)
97 Toyota GT4 ST205 1st run 16.2psi 181.2KW
more to come...
Post by sergei »
Where is the fuelstar dyno?
TRDmod
oh
Post by TRDmod »
not there yet, february next dyno day. the guy that does my car will get his own dyno soon on the shore, which should make it cheaper to dyno my car and yours!!
but feb next TP dyno day.
im jsut a little concerned with the low end, as i changed the turbo, the low end suffered though the top end greatly improved, wondering how i can bring up the low end slightly up to make it a more flatter curve. any suggestions. (cheap ones):)
Domino's Pizza.....
TRDmod
internals
Post by TRDmod »
see, the thing is, it will cost alot to do the whole internal side of things
though, if anyone here can recommend a cheaper alternative to enable me to pump up the boost say.. 18-21 psi... let me know
i mean i know doing the pistons and rings would be cheap.. wel relatively cheap, i mean pistons retail go for 1400 with rings, install, lets say 2200 to do so.... if i do that, would that enable me to pump up the boost hardcore with out doing anything else?
i hear the conrods on gt4s are strong, and the piston is the downfall of them...
any feeback ont hat, cos i really want a lil more power for the cheapest price, sure i can do computer 2200, all the engine internals 4k probably. just exploring ideas... i know i got told that you might aswell do everything if your gonan do pistons... its not much more
but u know.... money is money....a nd i dont have that much of it im willing to spend on this four wheel liability:)
Domino's Pizza.....
Post by Dell'Orto »
It'll cost you alot more than $800 to have a set of pistons installed ;)
To improve the low end, you can either A. Install antilag B. Bump up the base timing :lol: or C. Get some custom ground cams to help.
With a big turbo, you're never going to have the same low end power as a stock turbo, there is always going to be some sort of trade off.
Lith
Post by Lith »
Full boost at 4500rpm 8O Nice power though!
TRDmod
yeah
Post by TRDmod »
the turbo is big ish
thts why
but the top end power is definately very fun
but looking for cheap alternatives to get low end higher
Domino's Pizza.....
diss7
Post by diss7 »
Steel flywheel.
Won't imporve the dyno results, but sounds like the only answer to what you want/want to spend.
Adydas
Contact:
Post by Adydas »
Could it not hurt to TRY smaller intercooler pipeing? might be as simple as that? take what you got in to a pipe place and say replicate this as xx size as apposed to this being xX
TRDmod
mm
Post by TRDmod »
i see
what would decreasing intercooling piping do?
my theory: correct me if i am worng
because its smaller it takes less time to fill up and create a vaccuum pressure ont he pipes and intercooler
hence making it more responsive earlier on?
Domino's Pizza.....
Post by bluemaumau »
2.5 inch is plenty big enuf
diss7
Post by diss7 »
Have you done any fueling mods?
My st205 made 206kw atw too, then it went bang :lol:
Lith
Post by Lith »
Substantially improving low end really is only going to be done by going to a smaller turbo. What turbine housing does your turbo have? If its quite big (Ie, over .8x) then going to a .6x would bring things down a few hundred rpm. It'll still be nothing like stock, but should help and be a fair bit cheaper than changing the entire turbo.
Alternatively, sell the turbo and buy a smaller one - decide how much power you want.
GorGasm
Post by GorGasm »
decreasing the piping size may help response but it wont help with lag much.
The second graph looks nice power wise. I found torque didnt tune my car properly. Yours looks quite good.
Adydas
Contact:
Post by Adydas »
Whats the ecu?
Post Reply
