FWD 3S gearbox questions
Postby SUBARUCONVERT » Fri Dec 15, 2006 11:09 pm
hey, does anyone know if any of the FWD celica gearboxs have the same inputshaft spline as the GT4. also if the GT4 clutch flytwheel will fit in the bellhousing? and also the approx date/ model they went from cable to electric drive speedo.
any help would be great
3ST150
SUBARUCONVERT
Postby strx7 » Sat Dec 16, 2006 12:14 pm
if you put a GT4 bell housing onto an 4AGZE E58 type box you'd be sorted.
right bell housing, same spline, + lsd.
Postby SUBARUCONVERT » Sat Dec 16, 2006 1:14 pm
that is an option, but the prices for 4AGZE boxs are rather high and i personally have limited experiance with transaxels, could u use any 3S FWD bellhousing? or does it have to be a GT4 one to match the rest of the E58 ?
3ST150
SUBARUCONVERT
Postby strx7 » Sun Dec 17, 2006 3:21 pm
to match an E series box you could use the GT4 one or find an MR2 turbo gearbox, in which case you could use the whole thing.
Postby SUBARUCONVERT » Sun Dec 17, 2006 4:51 pm
yeah i think i wil just find a E153 and convert it to FWD shifter linkage
3ST150
SUBARUCONVERT
