15" offset.
15" offset.
Postby bluemaumau » Tue Dec 19, 2006 5:01 pm
hey eveyone looking at buying some 15 inch rp01s.
they have a offset of 45 will this be a problem?
theyre running 50 or 55 wall tyres.
ae101 btw
Postby Punter » Tue Dec 19, 2006 10:39 pm
How wide are they.
I doubt you'll have a problem, I have 15'x6.5' wheels +40 offset with 205/50/15 tyres. And I've got tons of room, much more than another 5mm.
Punter
Postby RED TOP MR 2 » Wed Dec 20, 2006 9:29 am
best thing would be to give them a try.
RED TOP MR 2
Postby aesc » Wed Dec 20, 2006 2:06 pm
+45 is Honda offset, they will fit but wont quite look right as theyll sit quite far inside the guard line
EX AE101 owner
2013 Ford Focus ST
aesc
Postby bluemaumau » Wed Dec 20, 2006 7:04 pm
thanks asec,
does anyone know if rp01s cam in a 38/40 offset?
Postby diss7 » Wed Dec 20, 2006 8:44 pm
Mate, honestly - you're not going to notice if the wheel is sitting 5mm further in/out.
RP-01's are popular wheels, don't turn your nose up at them over 5mm offset difference.
diss7
Postby bluemaumau » Wed Dec 20, 2006 9:40 pm
ok im not really in the know on offset, thought id better ask first
Postby diss7 » Wed Dec 20, 2006 9:47 pm
Without going into it, the higher the offset, the further IN they sit.
So the same width rim, one has +45 one has +40, the +45 rim will sit 5mm further in than the other.
diss7
Postby bluemaumau » Wed Dec 20, 2006 9:52 pm
thanks man, i may have found some honda mugen lightweight rims, which are nearly identical to rp01s! :D
Postby Punter » Wed Dec 20, 2006 9:55 pm
bluemaumau wrote:thanks man, i may have found some honda mugen lightweight rims, which are nearly identical to rp01s! :D
Its likely that they're an even higher offest, but it still shouldn't matter.
Punter
Postby bluemaumau » Wed Dec 20, 2006 10:00 pm
im gonna check it out, but im p-rety sure hondas are 45
Postby aesc » Thu Dec 21, 2006 8:15 am
diss1dent wrote:Mate, honestly - you're not going to notice if the wheel is sitting 5mm further in/out.
Yeah I guess 6.5" wide wheels would be alright. When I took my ae101 to the drags I used some 15x6 Mugen wheels on it and they were 45 offset and they looked $&#$% terrible, sat way inside the line of the guards. But yeah try them out and see how they look
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Pies » Thu Dec 21, 2006 9:56 am
your gonna want 15x7 with a 0 offset. phat.
Current Rides:
Pies
Postby bluemaumau » Sat Dec 23, 2006 11:01 am
okay so 45 will sit inside the guard, how will 7" wide wheels with 35p be? rubbing?
Postby vvega » Sat Dec 23, 2006 11:11 am
mine sat 225's inside teh guards on a 101 :D
ask ewan :D
vvega
Postby bluemaumau » Sat Dec 23, 2006 11:12 am
sweet!
