Flywheel Issues
Flywheel Issues
Postby BZG_UNIT » Thu Dec 21, 2006 5:01 pm
I have a late model ae92 gtz (1990 Facelift). I am transplanting a 4agze out of a aw11. I am unsure what flywheel will be the correct size that will fit in the bell housing.
Remember: ae92 gtz with standard g/box, 4agze from a aw11.
Cheers guys
1997 Toyota Trueno
1990 Toyota Trueno GTZ
BZG_UNIT
Postby Mr Revhead » Thu Dec 21, 2006 5:13 pm
itll fit
Postby BZG_UNIT » Thu Dec 21, 2006 5:16 pm
no the aw11 is auto so need to source a flywheel. what are my options? what can i get it out of
1997 Toyota Trueno
BZG_UNIT
Postby Mr Revhead » Thu Dec 21, 2006 5:22 pm
ok, helps if you give all the info :wink:
any 4agze flywheel will suit
just make sure you get the clutch to suit the flywheel.
Postby BZG_UNIT » Thu Dec 21, 2006 5:27 pm
thanks revhead..
You got any flywheel and clutch's on hand atm?
1997 Toyota Trueno
BZG_UNIT
Postby Mr Revhead » Thu Dec 21, 2006 5:29 pm
fraid not
Postby BZG_UNIT » Thu Dec 21, 2006 5:30 pm
thanks for your help anyway :)
1997 Toyota Trueno
BZG_UNIT
Postby l1ttle_d3vil » Thu Dec 21, 2006 6:45 pm
revhead - out of interest, how much are flywheels from toyota?
Postby bluemaumau » Thu Dec 21, 2006 8:27 pm
can you use a ae101 flywheel on a ae92 box tho?
Postby frost » Fri Dec 22, 2006 1:17 am
man we had some fun finding the right flywheel to clutch disc combo didn't we revhead.
what i ran into was as stated above you need the same clutch and cover as your flywheel. remember there are two sizes of the 4agze flywheel,
(well on the out side they look the same but its there surface friction area that is different)
as long as you get the same clutch and flywheel size you'll be sweet. like this
ae92 fly & ae92 clutch & cover into any 4agze box sweet.
ae101 fly & ae101 clutch & cover into any 4agze box sweet.
same rules apply in w5* box's
Postby Mr Revhead » Fri Dec 22, 2006 8:37 am
yes...... the difference isnt much, but enough that the covers are NOT interchangable.
as far as the g/box is concerned, no issue
Users browsing this forum: No registered users and 26 guests
