which doesnt happen in toyota gear boxes.
no_8wire wrote:As was said...not roller bearings....
but the ones that the diff rests against...eg the shims/race that you hammer into the casings...
But I stripped it down, check everything, nothing..well i will have one more try, and will use the shims from the other c50 box that I took the diff from see if that helps...
