They are located on the passenger side of the engine, about halfway along the block behind the starter motor.
It may also be worth mentioning that the engine is not turning over, not a sound from the starter motor, but the stereo works fine
Alex B wrote:To be fair you're never going to fit into OS unless you hate on TS.
big_boy wrote:pic #2 looks like starter solinoid you can check with a test light if you have 1
AE86less wrote:Sure is. Cheers for the help!
One question though, there is a lot of play on the gearstick (about 15-20cm movement while it's in gear). I had thought it was my old gearbox but after replacing it the problem is still there. I did transfer the old gearstick over.
What could be causing this? I assume it's something to do with the stick and the rubber and crap around it but i'm at a complete loss as to what is wrong.
ive heard of getting aftermarket aluminium ones which replace the standard nylon one may be worth checking it out.
AE86less wrote:I think thats the sort of thing RED TOP MR 2 meant. I don't know how similar that is to a k50. I guess i'll have to stop being lazy and relying on you guys :P
I'll go ask the local shop..
EDIT: Just out of curiosity, theres nothing to stop someone putting a t50 on a 3au is there?
