is my alternator naffed?
Postby SpeedRacer » Wed Dec 20, 2006 4:56 pm
pretty sure my alternator is screwd cos i can charge my battery and the car starts, but even after a good drive it wont start when I try start it again.
multimeterd across the terminals and it says approx 12v when running and off
Does this mean my alternator isnt charging my battery or that my battery isnt holding charge?
Sinister Sleeper 35
SpeedRacer
Postby RED TOP MR 2 » Wed Dec 20, 2006 7:26 pm
does sound like the battery they need like 12.4v to start a car.it will charge just wont hold it.
RED TOP MR 2
Postby SpeedRacer » Wed Dec 20, 2006 7:29 pm
sweet, was guna get one tomorrow and try it, and if it was wrong take it back :P. so if others are on the same track as me then ill go ahead with it.
who sells good batteries for a good price? any recommended brands?
Sinister Sleeper 35
SpeedRacer
Postby postfach » Wed Dec 20, 2006 8:03 pm
if the alternator is working there should be something like 13.8v when the car is running.....check to make sure all the wires are still attached properly to the alternator, make sure the belt is still there/tight enough, and borrow someone elses battery that works before you go buying a new one, just in case they won't let you take it back
postfach
Postby eritate » Wed Dec 20, 2006 9:21 pm
the battery should show 14.4v when the car is running :D
I am a timewaster. Ignore anything I say
eritate
Postby SpeedRacer » Wed Dec 20, 2006 9:32 pm
so the alternator is stuffed then?...
Sinister Sleeper 35
SpeedRacer
Postby postfach » Wed Dec 20, 2006 9:41 pm
postfach
Postby SpeedRacer » Wed Dec 20, 2006 10:21 pm
nice...
damit off 2 get it rebuilt :(
Sinister Sleeper 35
SpeedRacer
Postby Stealer Of Souls » Thu Dec 21, 2006 8:35 am
RED TOP MR 2 wrote:does sound like the battery they need like 12.4v to start a car.it will charge just wont hold it.
Interesting number... mine will start my car from 11.5V... that's as low as I've been, but it started so easily, I reckon I could go down another half a volt...
'86 AE85.5 Levin
Stealer Of Souls
Postby Zak » Thu Dec 21, 2006 8:55 am
It's the volt's while cranking that matter, you need I think 10V off memory while cranking, depending on what kind of ignition and stuff.
Zak
Postby Stealer Of Souls » Thu Dec 21, 2006 12:05 pm
It really depends on the battery and the car....
I think most won't have enough juice if they drop below 10V during cranking.
But if it's a big battery (or a small/low comp engine), and it's healthy then it might do the job down to 9...
'86 AE85.5 Levin
Stealer Of Souls
Postby Jdawg » Thu Dec 21, 2006 1:01 pm
Stealer Of Souls wrote:It really depends on the battery and the car....
Yeah, I got my Curren started on pretty low voltage, like rr,click,click,click,rr,click,click,r,brmmm, whew. Don't know what that translates to in volts tho
Jdawg
Postby Pies » Thu Dec 21, 2006 1:04 pm
8v is the lowest you can go before your car wont start. depending on the engine = how many amps you need to crank it over
Current Rides:
Pies
Postby SpeedRacer » Thu Dec 21, 2006 4:25 pm
ok took alternator in and auto aprky tested it and said it was fine, so now will see if it lasts a long drive to make sure its not my bad wiring :S
Sinister Sleeper 35
SpeedRacer
Postby big_boy » Thu Dec 21, 2006 4:38 pm
is it internal or extanal reged & have you checked thet if it extenal
big_boy
Postby SpeedRacer » Thu Dec 21, 2006 4:40 pm
4ages are internally reged?
Sinister Sleeper 35
SpeedRacer
Postby SuperSupra » Sat Dec 23, 2006 11:33 pm
Make sure the battery terminals are clean, just had a similar problem, car wouldn't start without a jumpstart but was fine once running, all due to dirty battery terminals....
SuperSupra
Postby NZ_AE86 » Sun Dec 24, 2006 9:49 am
SpeedRacer wrote:4ages are internally reged?
Most are. ;)
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby Helious » Sun Dec 24, 2006 10:52 am
14.4 when running..
Helious
Postby Adamal » Sun Dec 24, 2006 11:20 am
Sure your belt isn't buggered?
