Might i need a wheel puller? Or more weetbix?
Adamal wrote:This is XRyanX. His car is so low that he has to drive over speed bumps diagonally. HARDEN THE $$% UP XRYANX!!
Mr.Phreak wrote:I'm lazy and use a puller.....
And it may pay to put the nut back on for a few turns so if it lets loose it doesn't become all friendly like with your face.
Cahuna wrote:Try pounding each side of the wheel with your fists repeatedly (as if you are having the mother of all tantys), that normally shocks the wheel off the spline and you can just slide it off.
