Kahlua wrote:So that means you are all repaired and ready to go Matt?
matt dunn wrote:Kahlua wrote:So that means you are all repaired and ready to go Matt?
Not ready yet, but hey there's still a whole 24hours left.
Wont be there for friday practise, but finished the last of the reassemble tonight and have had a quick drive of it,
so a quick check over tomorrow night and the little things will be done at the track.
dont happen to have a program of events do you,
or know how many test qualifying and practise sesions we get on the sat??
Matt
Kahlua wrote:sh*t, just got back from the Test Day and forgot the programme.
We were a little bit busy, had a major mission the whole day.
Normally we run just one transponder system, but TRS use a different system, so we had to run 2 different units, and whilst our normal one (the one you will be using Matt) is going no worries, its proving a mission setting up the TRS one, and feeding live results (overall placings whilst race in progress) to Commentary, Race control & the TRS pit centre wirelessly.
Oh well, another early start tomorrow.
matt dunn wrote:Kahlua wrote:sh*t, just got back from the Test Day and forgot the programme.
That's ok, have it sussed now anyway.
see ya there
matt dunn wrote:I qualified 7th and finished 6th in the first race but had a lot of brake trouble so was braking really early at times, ( good 1-200m earlier at the end of the straight).
Traced and repaired the problems and started off pole for the second race.
Got raced off the line by the 4wd's as you expect, but once I got a bit if confidence in the car agian got down to really good times.
I actually beat the lap record.
Last years lap record was 1.33.9 and I did a 1.33.72.
Last years series champion did a 1.33.71, and finished just in front of me,
but the class speed has incresed so far since last year that the top 2 or 3 were doing 1.30's.
Got that whole race on incar camera so will host and post it onto the end of my other video thread.
Last race was reverse grid and due to my fast lap time was off near the rear,
but it blew the exhaust manifold gasket and became really lazy too boost so was not really in with a chance, so finished near the back and got disqualified for overboosting anyway as the boost controller had a hard time trying to keep the pressure right with the leak.
So really happy with the way it went.
Small couple of repairs and race again in Timaru in 3 weeks.
Matt
Matt
4000GT wrote:Thats great news about your times... shame about the little stuff going wrong. What boost controller did you end up going for? Since its capped at 18psi, why not go for a properly sized wastegate spring?
RedMist wrote:Sounds like a good outing after some serious work.
What boost pressure are you restricted to run? And how do they datalog it?
Return to Christchurch / Upper South Island Region
