rubber ends of lower arm. are they important?
Postby flygt4 » Fri Jan 05, 2007 1:57 pm
so i had a little mishap while extracting a cross threaded bolt in the most technical of ways, and was forced to drop out my front subframe and replace it. probly coulda had it welded up but didnt wanna risk it.
my question is are the rubber ends where the lower arm pivots in the subframe important? would you notice in any way if there were buggered?
after removing them ive noticed they are quite knackered, and since its all apart , i figure ill replace any and all parts that need it now rather than later. i never noticed anything i could blame on them before, so im tempted just to sling em back in and see.
heres a few pics to give you an idea.
damage to subframe :?
bit im suspicious about
a wider view of the part i mean
flygt4
Postby Lloyd » Fri Jan 05, 2007 2:01 pm
You'd fail a warrent if they were stuffed. Price up some through Repco and see what they're like, if they're cheap then chuck some Nolathane ones in and then you shouldn't have to worry about it for a while
EDIT - Assuming they're replaceable and not a complete arm
Postby flygt4 » Fri Jan 05, 2007 2:15 pm
they appear to slide over the top of the pivot , but i havent been able to get it off. didnt really wanna damage it too much.
flygt4
Postby Mr Revhead » Fri Jan 05, 2007 2:34 pm
thats a stuffed bush.
EMAIL me for an idea on parts :wink:
Postby flygt4 » Fri Jan 05, 2007 2:35 pm
already done :lol: ill probly make your guys bonus alone this month. oops no i pm'd you, email to follow :lol:
flygt4
Postby Mr Revhead » Fri Jan 05, 2007 2:40 pm
so you about to spent 10k? awesome 8)
Postby flygt4 » Fri Jan 05, 2007 2:41 pm
hahaha probly more like 2.5 :wink:
flygt4
Postby QikStarlie » Fri Jan 05, 2007 7:26 pm
definitly fix them. more solid the better. as more they more around, less traction you will get
QikStarlie
Postby flygt4 » Fri Jan 05, 2007 7:48 pm
apparently they are part of the lower arm, so im not so keen to to go to that extreme of replacing both arms :? i might see if i can fill it with urethane or something to firm it up tho.
flygt4
Postby Pies » Fri Jan 05, 2007 10:30 pm
txt me 2morro jizzface i hook u up with nolthane
Current Rides:
Pies
Postby Crucible » Sat Jan 06, 2007 9:52 am
flygt4 wrote:apparently they are part of the lower arm, so im not so keen to to go to that extreme of replacing both arms :? i might see if i can fill it with urethane or something to firm it up tho.
Remove the arm from the subframe and just blow the bushes out with a gas axe, the heat turns them to soft goo, then you can tap them out with a chisel. Keep the heat away from the arm itself though.
If the new bushes are one piece, you just need a bit of lube and tap them in with a socket, if they are 3 piece you can just push them in with your fingers.
Id just weld that subframe with a mig, It will be fine.
Crucible
Real Life Mechanic
Postby flygt4 » Sat Jan 06, 2007 10:49 am
was gonna weld it up :wink: but it only cost me time to put the new one in so it wasnt a major. i woulda had to get to a welder to fix the old one up.
flygt4
Postby Santa'sBoostinSleigh » Wed Jan 10, 2007 11:08 pm
and it cost me a subframe :( :P
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby THA SHZ » Fri Jan 12, 2007 9:54 pm
u need tofix tht asap , it will affect ur castor and also the handling on that side of the car 8)
THA SHZ
Postby flygt4 » Sat Jan 13, 2007 8:19 am
both sides are knackered so itll affect it evenly :lol:
flygt4
Users browsing this forum: Google [Bot] and 24 guests
