flygt4 wrote:yep new manifold/turbine housing. unsure as to whether you need to get a whole new turbo or can just get the manifold/exhaust housing.
factory casting was missing a bolt in the top left hand corner, as a result its common for the manifold to warp and crack. the replacement will have the extra hole.
i guess only god knows why they designed it this way.
warrick/mr revhead is toyota parts whore on here,and should be able to source you a genuine replacement at a very good price.
oh but you before you assume too much it may pay to confirm what your issue is, it could be something silly like an exhaust gasket, remove the heatshield and see if theres any visible cracking in top left hand corner of manifold.
Im afraid you have to replace the whole thing, toyota dont sell the manifold seperate. It almost seems like a when, not an if, with the pre-facelift GTT's. We do actually have a turbo in stock at the moment(I also work with the above mentioned MR REVHEAD), but its around $2000.
