1998 wrote:solitaire wrote:1998 wrote:Dont unplug the knock sensor the car will go into limp home mode.
Ah ok... given that the boys at tp says is was knocking a little bit is it likely to be safe to run without it? or do most cars knock every now and again?
Hmm its a little unprofessional for them to say that...
If the ecu cant see a knock sensor it'll think 'oh crap must protect engine' and kill all power to the engine, only providing enough to 'limp home' really slowly.
The way to blow your 3S-GTE is unbolt the sensor from the block and earth it manually while having it plugged into the ECU. The ECU can still see the knock sensor it because its plugged in but it will never detect knock because it is not in the block
The flip side is if you get a bad tank of gas on a really hot day, bad things could happen
fivebob wrote:1998 wrote:solitaire wrote:1998 wrote:Dont unplug the knock sensor the car will go into limp home mode.
Not really, all it does is massively retard the ignition, and if the stock boost control is still active it limits boost to about 7psi. You still get full rpm, though power is reduced and the exhaust manifold heats up rather quickly. A by product of the retarded ignition is that the turbo spools a lot quicker bit the engine is producing less powerThe way to blow your 3S-GTE is unbolt the sensor from the block and earth it manually while having it plugged into the ECU. The ECU can still see the knock sensor it because its plugged in but it will never detect knock because it is not in the block
Corrected for truthThe flip side is if you get a bad tank of gas on a really hot day, bad things could happen
No the flip side on a 3S-GTE is that bad things will happen....unless you're running an aftermarket ECU. These engines need the knock sensor with the stock ignition map and NZ fuel
Akane wrote:You know, you can always just come around to my place and I'll take a look at your car. I'm on the shore as well.... That's only if you trust the pixel mechanic.
