Help Anyone?
Help Anyone?
Postby DRTY.2 » Mon Jan 08, 2007 8:35 pm
Well I blew the gearbox in the mr2, so am looking for someone to help me replace it! I can pay well...
DRTY.2
Postby Bling » Mon Jan 08, 2007 11:52 pm
how did you manage to blow it?
dont have an mechanics as friends? i got no idea on mr2s, but from what i've read they are a right PITA
Postby Alex B » Mon Jan 08, 2007 11:55 pm
Not so bad, drop the subframe and you would be away laughing. Its not exactly a k series starlet though. :lol:
Postby RS13 » Mon Jan 08, 2007 11:57 pm
What exactly have you done to the gearbox? Are you absolutely sure that its' blown?
RS13
Postby Bling » Tue Jan 09, 2007 12:07 am
pyro_sniper2002 wrote:Its not exactly a k series starlet though. :lol:
damn straight, could do that 1 handed i'm sure :lol:
Postby hsmidy » Tue Jan 09, 2007 12:02 pm
ive pm'd ya
hsmidy
Postby DRTY.2 » Tue Jan 09, 2007 8:07 pm
Yes I'm sure it's blown. The car doesn't move at all (some guy said mr2's can't do skids so of course I had to prove otherwise...,) And I know it's not the clutch...
DRTY.2
Postby Elmo » Tue Jan 09, 2007 8:44 pm
How do you know its not the clutch?
If it doesnt move at all in any gear, forward or reverse, its definitly pointing to be the clutch, or input shft of GB atleast.
Elmo
Postby crispy'86 » Tue Jan 09, 2007 9:06 pm
if it makes really loud noises when you try and shift between gears and/or disengaging the clutch it'll be gearbox. Don't underestimate the clutch if you can change smoothly but there's no drive
crispy'86
Postby Dell'Orto » Tue Jan 09, 2007 9:06 pm
DRTY.2 wrote:Yes I'm sure it's blown. The car doesn't move at all (some guy said mr2's can't do skids so of course I had to prove otherwise...,) And I know it's not the clutch...
c
Hah, that was pretty intelligent! The gearboxes are reasonably strong, so you will have had to molested it fairly well to break it.
Checked the shifter linkages?
Postby DRTY.2 » Tue Jan 09, 2007 9:39 pm
I've had my chick mate who did a mechanics course look at it and said it was the gearbox and a mate of mine looked at it and said the same thing (and said clutch was fine). Everything seems normal in it, just doesn't go anywhere lol. I myself have no idea what I'm looking at lol.
DRTY.2
Postby RS13 » Tue Jan 09, 2007 11:52 pm
So what exactly happened when it "blew"? Big clunk?
If you start the car, does it make any odd noises?
If the car is running, and you put it into 1st and let the clutch out, what happens?
RS13
Postby DRTY.2 » Wed Jan 10, 2007 8:37 am
Um no, there were no noises at all. Doesn't make any odd noises when I start it. When I put it in 1st and let the clutch out it just revs, doesn't go anywhere.
DRTY.2
Postby diss7 » Wed Jan 10, 2007 10:02 am
Tell your mate shes a moron.
I've blown two gearboxes, 1st time car would drive and you could hear the pieces in the box flying around. Once of the fragments got caught between the cogs and then the car wouldn't roll at all. We crash started the car and the fragment went flying out the side of the gearbox.
2nd time was a GTiR. That litterally dropped its guts on the road. There was a pool of fluid and lots of fragments of everything.
It really reall sounds like a clutch to me!
diss7
Postby Mr Revhead » Wed Jan 10, 2007 10:07 am
why is she a moron?
iv seen boxes blow and go all noisey, and iv seen them "blow" and not be noisey
Postby JT » Wed Jan 10, 2007 1:32 pm
Mr Revhead wrote:why is she a moron?
Depends what 'DRTY.2' has classed at blowing. From the sounds of things she has just described it as blowing because the engine runs but the car has no drive.
Can you explain a bit more other than, I did a skid... Were you trying to change gears when drive stopped? Does the car not move with the engine running if you select any gear, incl reverse?
With the car in gear and engine off can the car roll? try with foot on the clutch and off. Can the car roll in neutral?
JT
Postby rallymazda » Wed Jan 10, 2007 6:23 pm
well watever the problem is if you want to go to a good workshop head down to Lichfield motors on durham st, we have done a lot of mr2 gearbox and engine replacments
[4AGE8U] << my old number plate
Got me a new altezza, now arrived
1991 corolla wagon- work hack
rallymazda
Postby RS13 » Wed Jan 10, 2007 7:07 pm
Put me down for $5 on clutch.
RS13
Postby DRTY.2 » Wed Jan 10, 2007 8:24 pm
OK...
Doing skid in 1st, took my foot of the brake... moved forward and changed to second and it just revved and didn't accelerate.
Now in every gear when you take the foot off the clutch it doesnt go anywhere. Also I can change gear fine without my foot on the clutch...
DRTY.2
Postby diss7 » Wed Jan 10, 2007 8:28 pm
After hearing that I'd like $5 on clutch also.
diss7
Return to Christchurch / Upper South Island Region
