pyro_sniper2002 wrote:Read it guys, hes just had the pads done, and alignment. And it takes quite a bit for ABS to start reacting. Unless its faulty, in which case the light should be staying on.
aesc wrote:I've been told that you shouldnt have Toyota rotors skimmed/machined as they are very close to the minimum thickness as they are. So by having them skimmed they are very possibly below the minimum thickness, and that may be causing the problem.
