Boosted_162 wrote:I think link is the only plug-in available? Ill be going for a G3 when i get round to an ecu, so much easier for the wiring noobs.
Cliff uses a Motec, will be nice to see his results.
LEM G3 + adaptaLink $1590 inc
Plugin replacement for Mazda (MX5/GTX/GTR), Nissan (R32/R33/S13/S14/S15/N14/GTiR), Subaru (WRX V1-6/RS), Toyota (SW20/ST185/ST205).
Akane wrote:Buy my PowerFC imo.
Adydas wrote:you can get a version that will work out of the box its been haxord by another company to work with the AFM as apposed to the apexi programmed MAP.
You need to find your self an AP engeneering Power FC.
you SHOULD find this to be the part number to
4E14T04Z
mister2 wrote:Depends on your requirements - Link LEM G3 + adaptor for $1590 is pretty hard to beat value for money. If you want to run over 22psi boost you'll need the MAP sensor upgrade ($135 for 55psi). PowerFC are good but a little dearer.
MoTeC are great too if you have the datalogging requirements and the bank balance.
Nick
Akane wrote:My AP Engineering PowerFC was pay & plug & play on my Gen 2 3S-GTE MR2. I paid extra for this version which is repinned and has software loaded for the Gen 2's MAP sensor.
