What do you think of this?
Postby ollieboy » Sun Jan 14, 2007 10:47 pm
Earlier in the year I blew a head gasket and the head was a bit rooted so I got some work done on it. Due to the work I had to run 95 octane at the least but someone borrowed my car and filled it up with shell 91. I never fill up at Shell usually.
The engine doesn't pink so I'm driving it with the 91 but it's incredibly gutless and the spark plugs fouled in less than a day, I only gave the car a tune up a week ago.
Do you think its gutless due to the fuel, fuel quality or something else?
Its got me slightly worried but I can't put new gas in yet because its a full tank and theres no drain on the bottom of the tank to get the gas out.
ollieboy
Postby fangsport » Sun Jan 14, 2007 10:51 pm
play with the timing and change to a hotter plug??
is the filter blocked?
fangsport
Postby ollieboy » Sun Jan 14, 2007 10:54 pm
Will have a look tomorrow now I know what to look for. Now you mention it, filter is pretty old and probably could do with a change anyway. I just used the listed NGK plug when I changed them so unsure.
ollieboy
Postby RS13 » Sun Jan 14, 2007 10:55 pm
What car is this in? the 2T?
RS13
Postby ollieboy » Sun Jan 14, 2007 10:56 pm
Yep 2T
ollieboy
Postby fangsport » Sun Jan 14, 2007 11:02 pm
ollieboy wrote:Yep 2T
they would have needed to take a massive amount off the head to bump the compression up enough to require a higher octane.
check fuel delivery
fangsport
Postby ollieboy » Sun Jan 14, 2007 11:03 pm
Yeah it was only a wee bit, just the buckled area but the cylinder head repairer said run 95 just in case.
Edit: He wasn't too sure about Toyota engines but I looked in the manual for 2t and it said minimum octane 89 so I think he worked out it should be ok for 91 but just in case.
ollieboy
Postby Caveman » Sun Jan 14, 2007 11:22 pm
Ummm maybe the person you lent it too trashed the tits off it?
AW11 Track Toy
Formerly known as 1998
Caveman
Postby ollieboy » Sun Jan 14, 2007 11:24 pm
The person I leant it to is my 50 year old mother who works for the NZ police, I don't think she "thrashed the tits off it." :)
ollieboy
