Exhaust WOF Issue.
Exhaust WOF Issue.
Postby Stupra » Tue Jan 16, 2007 8:20 am
Recently i bought a 93 Supra with a big single turbo and 3.5" HKS exhaust system.
I failed a WOF on it recently and need to quiten it down a bit.
Apparently pit stop who i took it to initially do not have resonators in 3.5" size and dont really want to hack up the expensive exhaust which is fair enough. Sadly though I have no option but to add something in there or have the rear section replaced temporarily as it is has a 4 bolt flange which can be removed easy enough.
Anyone have any suggestions where i can find a 3.5" muffler / resonator??
Or preferably fabricate a temporary rear section with a quiter muffler?
Pit stop cannot find a flange apparently so anyones advice from here would be appreciated greatly! :-)
STU.
Owner of Auto1 Whangaparaoa - ill hook you up!
89 Supra Turbo.
96 Supra RZ-S
http://toyspeed.blakjak.net/profiles/profile.php?id=398
https://www.facebook.com/pages/North-Ha ... 2488332604
Stupra
Postby Silent Knight » Tue Jan 16, 2007 8:26 am
From a very quick search here's one for 3".
I'm sure if you had a decent search you'd be able to track a 3.5" down somewhere... :wink:
http://www.aeroexhaust.com/aero_resonator_ar30.html
Silent Knight
Postby Arthanon » Tue Jan 16, 2007 8:31 am
I can do a 3.5", but it is a truck muffler. Not massivly big (178mm outer diameter, 500m length)
Probably not what your looking for.
Current Ride: 1998 GT Caldina 3S-GE BEAMS Goodness
Previous Ride: 1994 Curren 3S-FE Not so Goodness
Arthanon
Postby Adydas » Tue Jan 16, 2007 9:43 am
Cant you claim its like that stock or is it HKS?
Adydas
Postby sergei » Tue Jan 16, 2007 9:53 am
How loud it is? If it is not overly loud, you could try to go to friendlier WOF inspector...
Postby postfach » Tue Jan 16, 2007 10:11 am
PM'd
postfach
Postby big_boy » Tue Jan 16, 2007 10:13 am
get a bit of sheat metal the same size as the flange put the 4 mounting holes in it & then put a 1-1/2" hole in it
iv been doing this on my supra for the last 2 warrents it makes it quiter by a lot but also makes it a guttless sack
big_boy
Postby no_8wire » Tue Jan 16, 2007 10:16 am
I have a 3" Coby if you need it...
no_8wire
Postby IH8TEC » Tue Jan 16, 2007 11:05 am
big_boy wrote:get a bit of sheat metal the same size as the flange put the 4 mounting holes in it & then put a 1-1/2" hole in it
good idea that man 8)
Postby Stupra » Tue Jan 16, 2007 4:56 pm
Brilliant idea!! before anything else, im going to try that.
Otherwise ill shop around for WOF shops.
I had the WOF done at my previous job so they know me all good and usually dont worry about much. But i guess its just too loud for them Pussys!
Cheers.
89 Supra Turbo.
96 Supra RZ-S
Stupra
Postby TRDGT4 » Wed Jan 17, 2007 4:07 pm
Have you tired Rage Big Bores down south they might have something
TRDGT4
Postby gleem » Wed Jan 17, 2007 7:15 pm
Go to a different wof place? Theres one place in view rd, glenfield that passes almost anything.
gleem
Postby flygt4 » Wed Jan 17, 2007 8:59 pm
really doesnt pay to mention lenient wof inspectors on a public forum, probly better in pm :wink:
flygt4
Postby solitaire » Thu Jan 18, 2007 12:09 am
Can i be in on the pm too please? i currently drive to pakuranga from albany for mine :(
AE92, KZJ120, KDJ120
solitaire
Postby Silent Knight » Thu Jan 18, 2007 9:41 am
solitaire wrote:Can i be in on the pm too please? i currently drive to pakuranga from albany for mine :(
Heh... might as well go to Otahuhu.
Can get a WOF for a pack of chips or a splif over there... :lol:
Silent Knight
Postby solitaire » Thu Jan 18, 2007 9:45 am
:D Sweet... I think thats got to be the winner, Last wof my misus decided to be helpfull on her day off and took the MR2 to VTNZ... I swear i nearly slapped her when i found out... $400 later i had my wof....
solitaire
Postby JT » Thu Jan 18, 2007 1:43 pm
solitaire wrote: :D Sweet... I think thats got to be the winner, Last wof my misus decided to be helpfull on her day off and took the MR2 to VTNZ... I swear i nearly slapped her when i found out... $400 later i had my wof....
$400 doesn't cover much, especially if tires or labour is involved, though they don't do any work so what exactly needed doing?
Our local VTNZ station aren't picky bastards so my mate goes there before he sells a car, people think there's more merit to the fact it passes at VTNZ.
JT
Postby Prymal » Thu Jan 18, 2007 6:28 pm
Are you running a high flow catalytic converter in this setup ?
A cat , while a bit costly , and at the sacrafice of a few HP will effectively quieten down an exhaust system also - Modern cats dont sacrafice much though these days - technologys improved alot
Youll also make all the birds bees and butterflies happy by making less emissions
Prymal
Users browsing this forum: Bing [Bot], Google [Bot] and 17 guests
