I understood this far...no_8wire wrote:As far as I can remember therr is no rev limit
What is the rev limit bar valve bounce?no_8wire wrote:bar valve bounce on all 16V 4ages
Dirtbag wrote:My mates redtop deff has a rev limiter, I have never been in an EFI car without one.
JRS wrote:i'm fairly sure you don't know the difference between rev limiter and valve bounce. even if your 4age DID have no limiter, ther's no way valve bounce would occur at 7600 rpm (unless the springs are really tired).
Nope. Still running the AE85 dash so no speed sensor output (or at least I don't think it's got one).Caveman wrote:Do you have speed sensor going into ecu?
Do you mean the same ecu unit or different ecu units? I always thought mine went up to 7800 before cutting, but when I was on the dyno the sheet came back with a 7300ish cut. I thought it was weird, so worked out how fast it would've been going in that gear at that RPM and sure enough, 7300ish when it cut...NA Drifter wrote:Sometimes it cut at 7200rpm, 7400rpm, sometimes 7800rpm still std ecu..
