Camber plates: Where can I get them made?
Postby no_8wire » Sat Jan 20, 2007 7:10 pm
As above, I am after some camber plates for my AW11, but dont want to pay $600+ US for the only ones I can find on the net. ( after front and rear)
Anyone know who I could contact to get some made?(Auckland based)
no_8wire
Postby Bazda » Sat Jan 20, 2007 7:59 pm
Precesion Engineering in Albany, Jeffrey Bruce.
Postby evil_si » Sat Jan 20, 2007 11:54 pm
have you tried stocks, they are off carbine road, cant remember the street name,
they have allsorts on the shelf and have a machine shop were they can modify or make to suit you application.
evil_si
Postby JRS » Sun Jan 21, 2007 2:41 am
tien adjustable mount from autoline. no idea what they're worth.
meh.....
JRS
Postby Cahuna » Sun Jan 21, 2007 7:55 am
Stocks do everything - the plates (which you drill to the pattern at the top of your strut tower) and the slider plates/roller bearing top mount. The plates from memory were approx $120 each, couldn't tell you the slider plates price.
However, if it is just the plates themselves (ie: you already have slider plates/roller bearing) then go to Precision Engineering FTW. Took my old weak-as 6mm alloy ones in as a pattern and for $60 each they made me some beautiful, much stronger 10mm alloy ones
We know that four-wheel drive doesn't work in a racing car, and I proved to myself that it doesn't work very well for rallycross. I'm absolutely convinced that it has no future in rallying, either, even if the regulations allowed it. - Roger Clark (rallying legend), circa 1976
Cahuna
Postby 86 Power » Sun Jan 21, 2007 8:51 am
Or you could talk to Eugine from 86 Factory. He imports T3 camber plates. Real nice! You could get some with out any holes, and drill them to suit your car. Or just redrill the AE86 T3 one.
86 Power
Postby no_8wire » Sun Jan 21, 2007 9:27 am
I need the complete unit, eg the plates and slider plate/bearing
no_8wire
Postby MrDori » Sun Jan 21, 2007 11:53 am
Bset bet would be find some that fit and either drill the plate to suit or drill the strut tower to suit
Garage Slipway- Super rarity
1g-gte powered gx61 creditstar
MrDori
what he said
Postby TOYROTA » Mon Jan 22, 2007 12:39 pm
as evil_si said try stocks 8 te apunga pl off carbine road in mount wellington.
or ring 09 2707222 and ask to speak to edgar in the service department
Curre3nt rides-
1982 starlet kp61 4 door (in panel shop getting bare metal resto)
1980 tt132 corona wagon 3t t40 (daily doomsday machine)
TOYROTA
Re: what he said
Postby THA SHZ » Sun Jan 28, 2007 10:29 am
TOYROTA wrote:as evil_si said try stocks 8 te apunga pl off carbine road in mount wellington.
speak to edgar ? good luck he hasnt been there for a while and i doubt they will put u through to him in aussie :lol:
No 8 wire , let me know if u wana get them from stocks and il will put u on to the rite guys .
THA SHZ
